Question about RCA F36649 36" TV
Connecting a playstation
How do you get a playstation to work on this tv
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
Pioneer vsx521 stopped recognising hdmi connection from computer
Press the Audio Parameter button (Looks like an x) then scroll up until you see 'HDMI AMP' and hit over to the left or right so it shows 'HDMI THRU' the HDMI will redo the handshake and you should have sound.
Mar 12, 2017 | Pioneer Audio Players & Recorders
I have a panasonic Th-42pv500a. I'm trying to connect my ps3 Via HDMI but it won't work. The ps3 works in my other tv with the same HDMI cable. And the foxtel box works in the panasonic with the same HDMI...
the playstation detects that you are changing display settings. hopefully you still have the old red yellow and white cord that we all used to use to plug in stuff to your tv . use this cord to connect your playstation to the tv, it should pop up that you want to change display settings. then after you go through that unplug and recconect the hdmi and it should run you through it again, Another option - when you plug in your ps3 to the tv , turn everything on the tv and playstation. if nothing pops up turn off your tv and playstation , literaly unplug them from the outlet for a good minute then plug everything back in and you should fix it that way. hope one of these work
May 04, 2011 | Televison & Video
Hi! I have a playstation 3 that I can`t get connected with my old panasonic tv from the stone age, around 1999. It has of course no hdmi. It is no problems connecting the playstation 2 on the same...
Hold the power button down as you turn it on until you see something on the screen and it should bring up the default screen resolution. If you are using the PS2's video connector, then it should work. If this does not work, you should try it on a different TV.
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
The playstation 3 wont connect to the tv it all
Sounds like a bad hdmi cord...if the a/v works.
Jan 03, 2011 | Sony Playstation 3 (PS3) Console
Playstation 3 will not come on screen when I connect hdmi cable to tv. tv not recognizing hdmi. What do I do?
Try resetting the playstation and a hot swap. Turn off the tv and the playstation and remove the hdmi cable from the television. You should see a red standby light on the playstation. Press and hold down the power button until you hear two beeps. Now plug the hdmi cable back in. Turn the television on. Turn the playstation on. Hope this works.
Oct 08, 2010 | Sharp LC22DV24U 22 in. LCD TV/DVD Combo
Playstation 3 - picture doesnt come up on tv
hold center button for a couple minutes with all cables connected to your tv this will allign your system with your tv
Jul 16, 2010 | Sony Playstation 3 (PS3) Console
No signal received for av playstation 2
Change the Video input on the tv. if that doesn't work check your connections.
Nov 26, 2008 | TruTech PVS31170S1W 17 in. LCD Television
Playstation
I assume you are connecting to your "old" tw with aydio/visual connections. Make sure that the yellow connection is plugged into the vide connection on your tv, not one of the audio connections.
May 28, 2008 | Sony PlayStation (PS) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
RCA F36649 36" TV Logo
16 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
