How do I change the Date and Time Setting on my Sony Cybershot DSC- W290 12.1 Mega pixel digital camers
SOURCE: Sony Cybershot DSC-W100 Digital Camera
This does depent on the software you are using to print the images- The data is in the images the computer programs has to find it. What program do you use to print?
SOURCE: How to change date and
Turn on the camera
select a setting item with up or down arrow
select date and time format
select daylight savings
then set date & time
SOURCE: New computer, cannot locate disc
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
