Vanity mirror light bulb is burned out. Do you replace just a bulb or do you have to replace more than just a bulb.
SOURCE: Service Vehicle, Trac Off, & ABS lights 2001 Buick Century.
I just put in new fron pads in my 2000 buick century and the track off and the anti lock brake light and the service engine soon stays on
SOURCE: how do i change the front turn signal bulb in my
k you will have to pop out the whole light fixture and there should be a conduit where the bulb is conected to just turn it and take it out and replace the bulb
SOURCE: how to replace a coolant level sensor, 2000 buick century
The coolant level sensor is located on the radiator. If you are looking at the engine from the front of the car it will be on the left side. There will some kind of clip holding it in the radiator. Removed the clip and pull the sensor out. You will lose coolant so try to swap it out quick or drain some of the coolant out. Once new sensor is installed, install clip to keep the sensor in place and reconnect the wires to the sensor. Crank the engine and make sure the coolant level is full. This should correct your problem.
SOURCE: I need to replace the 99 buick century side mirror
There is a small plastic piece (triangular shape) at the top of the door panel, opposite of the mirror. It is held in place by a plastic clip. You can gently pop that out, with a flat blade screwdriver or something similar. That will expose 3 bolts with nuts on them. On my 2000 Century, they are 10 mm. Take off those three nuts, and the mirror will come off.
SOURCE: How do I replace broken 2002 buick century passenger side mirror?
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
