Question about GoVideo VR3845 DVD Recorder/VCR
DVD's I have recorded on my GoVideo player will not upload on my PC and play correctly. How Do I convert to use on my PC & the Corel Videostudio Pro x series software? I have a few that a frie
DVD's I have recorded on my GoVideo player will not upload on my PC and play correctly. How Do I convert to use on my PC & the Corel Videostudio Pro x series software? I have a few that a friend converted, but they will not import into the Corel softeware. Signed, frustrated user!
Posted by John Hut on
Stan Brown
    New Friend:
    Problem Solver:
  • 9 Answers
If this is a DVD Recorder, you must be sure that DVD -/+ discs are FINALIZED. The discs you've recorded should also be checked on another DVD player other than the one they were recorded on. If not finalized, they will play nowhere else but the recorder they were recorded on.
I’m happy to assist further over the phone at https://www.6ya.com/expert/stanley_d05f392d8fafa669
Posted on Sep 07, 2012
5 Related Answers
paul proctor
  • 4102 Answers
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
Posted on Nov 26, 2007
Rick Kaufmann
  • 4 Answers
SOURCE: copy a vhs to a dvd on govideo dvr4200
This model is a DVD player only. It does not record to DVD's. You would need to get a model that has a DVD recorder.
Posted on Jan 09, 2008
Anonymous
  • 440 Answers
SOURCE: Degraded Signal quality
u would need a s video or coumpunt cables going into it
Posted on Feb 06, 2008
Anonymous
SOURCE: GoVideo VR3845 Replacement DVD Drive
My model is vr3845 some parts are missing , because of that i can not use the video. Where can i get the part?
My zipcode is 10037
Posted on Jul 13, 2008
Anonymous
  • 111 Answers
SOURCE: My computer says a finalized dvd made on govideo vr3930 is blank.
Sounds like your computer only reads certain disc's like dvd-r or dvd+r check to see if the burned disc is the same as the original? Second Could be that you really did not finalize? good luck, safety first..
Posted on Mar 09, 2009
Recorded GoVideo DVD-R will NOT play in any other DVD player
most dvd players have a region code and you must know what code yours is in, oryou can't play any dvd's, try and find your dvd code,by the way you can only change the code ,think it is 5 times , then it will stay in that code and cannot be changed.
Oct 10, 2012 | GoVideo VR4940 DVD Player/VCR
What video formats will RCA DRC279 DVD Player read
Hello
This player is compactable with DVDs, ACDs, Video CDS, CDs and JPEG files. You can't play the following type of discs. Laser discs, CD-1, CD-ROM, DVD-ROM, or discs recorded using other boradcast standards (ie PAL or SECAM); CDG discs.
If you want the user manual to this player, inform me by fixya comment, along with your email address. I'll send a copy of the user manual to you by return mail. It has all details. I can't send it to you by this window, as it does not allow ma to upload PDF files by it.
http://www.dataentryjobs.us/67948.html
Feb 27, 2012 | RCA DRC279 DVD Player
We have a GoVideo vcr/dvd recorder, but I cannot find the model number. It has a date on it of Sept., 2004. We have a video tape taken from a Sony camera, suing a Mini DV 6 tape and transferred it on...
Sorry u can't do anythings to the finalize codes,the dvd coppy process,the machine auto finalizing progamming codes belong to that machine done it by itself.Some compannies protect it softwares codes don't share with other in the industries.That why some programming codes copying dvd is finalizing in one machine.Can be used in that machine only or it partners olny.Check,if the dvd can be play in the computer?Buy a DVD coppy software for a computer.Recopy the DVD throught the computer software.The computer softwares have common sharing finalizing codes in the industries.U will be able play it in any DVD players.
Sep 17, 2010 | GoVideo Go Video DVD/VCR Combo
How do you record a VCR tape to a DVD?
Import the video on your pc using something like
http://www.newegg.com/Product/Product.aspx?Item=N82E16815260028&cm_re=av_card-_-15-260-028-_-Product
and convert it to dvd format using the supplied software..
Jan 16, 2010 | GoVideo VR3845 DVD Recorder/VCR
I recorded from tv to dvd and cannot play back video
upload it to your computer, and check the file type, and possibly convert it to the correct file type and burn it to a DVD.
Nov 15, 2009 | JVC DR-MV80B DVD Recorder / VCR Combo
When i record on go video dvd it only works on go video dvd player,not on other dvd player i recorded on _r and+r dvd
After you finish recording goto setup, DVD menu, and finalize the DVD this will allow it to be played on other players.
Nov 10, 2009 | GoVideo VR3845 DVD Recorder/VCR
Mar 09, 2009 | GoVideo VR3930 DVD Player/VCR
Digital converter box
You need to select channel 3 or 4 on your VCR! , or line-in if you connected through the (yellow/ white/ red) cable "better video quiality!" and selct the channel you want to record on your DTV box, not the VCR!
Sep 13, 2008 | GoVideo DV2150 DVD Player/VCR
GoVideo VR3845 DVD Recorder/VCR Logo
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
scramblepad
scramblepad
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
