Question about Samsung ML 2010 Laser Printer
Left side of printed page is faded
Left hand side of every print I do is faded like this, to the point of illegibility: http://imageshack.us/photo/my-images/35/20120808163828.jpg/ (don't mind the noise) This has been going on with old cartridge as well as with NEW replacement cartridge. So it's clearly NOT cartridge- or ink-related. Manual suggest cleaning the LSU (long strip of glass) - but I cannot find it. No surface inside of the printer that I can find is not made of glass. Any suggestions? Thanks!
Posted by Ji?? Fiala on
2 Related Answers
Anonymous
SOURCE: Printing faint on left hand side of page
I had a similar problem, which I fixed by carefully wiping the drum with a soft tissue.
Posted on Mar 22, 2009
Rafique Mannasaheb
  • 406 Answers
SOURCE: uneven black ink printing
This is the problem of the black developer in the imaging unit. Please contact authorised service center they will change for you.
Best Regards
Posted on Nov 15, 2009
Was told need new "drum assy" because of faded
sir/mam drum do go bad after so many copies and prints. normally machine will indicate when that is needed.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 04, 2011 | Samsung Office Equipment & Supplies
I have an hp laser printer 2550. all os a sudden
What has wrong is the toner cartridge holder has jumped a tooth and thats what is causing it. It is a easy fix but very hard to tell you over fixya. Steven 818-888-0006
Mar 12, 2010 | HP Color LaserJet 2550n printer + HP Color...
Print on left hand side of page is faded as you look to the middle and right hand side of page print is clear
Place one hand either side if printer,
Gently shake the printer left and right a few times without lifting it off the desk..
What happens is that when a laser printer is moved and is not kept level the toner will move to one side or the other, the gentle shake evens out the toner.
Jul 01, 2009 | Canon LBP3200 Laser Printer
Print fades out from right side of page
Check out this website it will assist you with all the known printing problems out there,
This could be anything from a transfer roller to a defective ink cartridge. However the above link is for troubleshooting print quality problems with your printer
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=239135&prodTypeId=18972&prodSeriesId=239135&objectID=bpl12234
May 27, 2009 | HP LaserJet 1500L Printer
Samsung SCX4216 MF
Called in a Samsung technician to fix/replace scanning unit
Oct 13, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Only top quarter of page is printed
How can a get the # recalled of a document was fax to.
Sep 02, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Print fading down right hand side
I was able to fix it by taking off the top of the printer. This involved taking off 4 screws on the top of the printer. I then had to disconnect the wires going to the control panel by unhooking them from the right side. I then located a thin rectangular box which I'm assuming houses the laser. I removed this with 4 more screws and turned it over. There was a little metal flap that I moved back and below was the mirror the lasers shoot on before going onto the toner.
In the same spot where I was having fading, I noticed a lot of toner on the mirror, so I cleaned it of, put it back together, and the fading was gone.
This was after I tried a new toner and maintenance kit.
Hope this helps
Apr 22, 2008 | HP LaserJet 4350 Printer
HP 2840 Colour Laserjet Printer Problem
Don't ever use compataable cartridge for printing .
(1)Check for printer sleave damage....
(2) check for any noise from printer when printing noise from fuser section.
(3).. Print a Demo color level page ...
(4)Check for scaner section ......
Thank you.
Feb 04, 2008 | HP Color LaserJet 2600n Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Samsung ML 2010 Laser Printer Logo
80 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
