My Dell laptop screen has suddenly developed a Red hue which I can't get rid of
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero. hope this helps
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
SOURCE: Dell laptop screen view
hello friend
its graphic properties
simply press ctrlkey + aerrow keys in different direction.....your bview will change accordingly
or check this combination
ctrl+alt+ aerrow keys
SOURCE: I have Dell Inspiron 2200 laptop. My laptop's
The lines indicate a slow failure of the LCD and it is progressive. The system can be connected to a VGA monitor and you can select the External display using Fn + F8 key combination.
LCDs are about $100 on EBay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+2200+LCD&_sacat=See-All-Categories
SOURCE: Suddenly died. PSU ok - will not boot up
Most likely, since there is no power or boot indication at all, it may be a motherboard failure.
Here is a link on basic troubleshooting:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
SOURCE: how do i get rid of several vertical lines down
There is only one way to get rid of vertical lines on your desktop, that is to reseat the video card if the card is separate with the motherboard. Otherwise, you need to call a technician to check your laptop for repair. To check if the video card is separate, turn off the laptop, remove the cables and battery, press and hold power button for 8 secs, remove the screws inside your pc, remove the hard drive, remove the optical drive, remove the fans & heat sink, remove the power supply. Then check if the video card is embedded on the motherboard or not.
SOURCE: Dell inspiron 1545 laptop (Time- of- date clock
This could mean two things: a problem with the cmos battery or the motherboard itself. Try to remove the cmos battery first and install. If not,then replace the cmos battery.
