Sony STR-DE525 Logo
Question about Sony STR-DE525
How do you replace the fuse? - Sony STR-DE525
Posted by patrick_d680 on
2answers
Where is alternator fuse in 2004 Navigator?
You can find a selection of replacement fuses in the fuse box. Sometimes, they are located on the inside of the fuse box cover. Replace the alternator fuse by pushing the new one into place using your fingers.
https://itstillruns.com/replace-alternator-fuse-7608082.html
Blown fuse on fuel pump 1996 Ford explorer Replaced fuse drove vehicle home. Now it will not start.
A blown fuse is an indication of circuit overload. Did you replace the fuse with one of the same value or higher? is this the standard current rating for that circuit (usually marked on the fuse cover.
If the engine cranks remove a spark plug tape it to the intake manifold or somewhere where there is clean bare metal (please not near the battery) check for spark if ok reinstall plug if not replace the ECM fuse and relay with alternatives in the fuse box if this gets the pump going replace the ECM fuse and or relay then check for fuel turn on the ignition you should hear the pump run and then shutoff if not replace the pump fuse and relay with alternatives in the fuse box if this gets the pump going replace the pump fuse and or relay
Replacing 140 amp fuse in lexus gx 470
Replacing 140 amp fuse in lexus gx 470 - Fixya
www.fixya.com/.../t26021201-replacing_140_amp_fuse_in_lexus_gx_4...
24 mins ago - The battery in my lexus gx 470 needed to be replaced it was hooked up wrog and the 140 amp fuse was blown how do i replace the 140 amp ...
HOW DO I REPLACE THE 140AMP FUSE ON A LEXUS ...
www.fixya.com/cars/t24496313-replace_140amp_fuse_lexus_gx470
May 24, 2014 - HOW DO I REPLACE THE 140AMP FUSE ON A LEXUS GX470CAN"T GET THE FUSE BOX APART TO UNBOLT THE FUSE - Dodge 1997 ..
1helpful
2answers
Show how to replace power outlet fuse for 2006 Toyota Camry
Interior Fuse Box Location 2002 2006 Toyota Camry 2006 Toyota Camry LE 2...
The video above shows how to replace blown fuses in the interior fuse box of your 2006 Toyota Camry in addition to the fuse panel diagram location. Electrical components such as your map light, radio, heated seats, high beams, power windows all have fuses and if they suddenly stop working, chances are you have a fuse that has blown out. If your Camry is experiencing electrical problems, you should always check the fuses first, because they are relatively easy to check and cheap to change. Some Toyotas have multiple interior fuse boxes including in the trunk - the video above will show you where the interior fuse box of your 2006 Camry is located. If your Camry has many options like a sunroof, navigation, heated seats, etc, the more fuses it has. Some components may have multiple fuses, so make sure you check all of the fuses that are linked to the component in question.
If you need to replace a blown fuse in your Camry, make sure you replace it with one that has the same amperage as the blown fuse. If checking and replacing the fuse for the component in question doesn't work, we recommend seeking assistance from a trusted professional mechanic. They should be able to figure out if the component needs to be replaced or if there is a short or some other problem with your Camry.
Good Luck
Black decker bna17 mini fridge
I am having the same problem. Replaced the fuse with fuse holder and 3A fuse but the new fuse blows immediately. What do the diodes look like? and how do you replace them?
Outside fusebox location on Pontiac Montana 2005 3.4L the one under hood
FUSE BOX
There are few related help links for vehicle fuse box.Go through the list and click the required link:-----
2009 Toyota Corolla: Fuse Box Module Removal?
http://howtobyme.blogspot.in/2012/05/2009-toyota-corolla-fuse-box-module.html
1986 Chevrolet Corvette Fuse Box Diagram
http://schematicsdiagram.blogspot.com/2012/11/1986-chevrolet-corvette-fuse-box-diagram.html
1996 Chevy Cavalier Cluster Fuse Box Diagram?
http://schematicsdiagram.blogspot.in/2012/04/1996-chevy-cavalier-cluster-fuse-box.html
2004 Jeep Cherokee Fuse Box?
http://whatisbyme.blogspot.in/2012/05/2004-jeep-grand-cherokee-fuse-box.html
2007 Saturn Outlook Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2007-saturn-outlook-fuse-box.html
Lincoln Signature Series Engine Compartment Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/lincoln-signature-series-engine.html
2005 Chevy Impala: Fog light Relay and fuse box diagram?
http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-fog-light-relay-and.html
Freightliner fl112 fuse box diagram?
http://technoanswers.blogspot.com/2012/01/freightliner-fl112-fuse-box-diagram.html
Where is Fuse box located on 2002 Honda Accord?
http://howtobyme.blogspot.com/2011/12/where-is-fuse-box-located-on-2002-honda.html
Toyota Hilux Surf Fuse Box Diagram?
http://technoanswers.blogspot.in/2012/06/toyota-hilux-surf-fuse-box-diagram.html
2006 PT cruiser Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2006-pt-cruiser-fuse-box.html
Ford inside fuse box diagram showing fuel pump relay?
http://technoanswers.blogspot.in/2012/02/ford-inside-fuse-box-diagram-showing.html
Ford fuel pump fuse layout diagram?
http://technoanswers.blogspot.in/2012/02/ford-fuel-pump-fuse-layout-diagram.html
Saturn Fuse Box Diagram
http://schematicsdiagram.blogspot.com/2012/11/saturn-fuse-box-diagram.html
"Mercedes Benz" Ml 500 "Fuse Box Diagram"
http://schematicsdiagram.blogspot.com/2012/11/mercedes-benz-ml-500-fuse-box-diagram.html
2003 Cadillac Deville DTS Underhood Fuse Box Diagram
http://schematicsdiagram.blogspot.com/2012/11/2003-cadillac-deville-dts-underhood.html
Kia Fuse box?
http://technoanswers.blogspot.in/2012/02/kia-fuse-box.html
Which Fuse controls A/C system on 2003 Ford Taurus?
http://howtobyme.blogspot.com/2011/12/which-fuse-controls-ac-system-on-2003.html
1997 Chevy Malibu Cigarette Lighter Fuse?
http://schematicsdiagram.blogspot.com/2011/12/1997-chevy-malibu-cigarette-lighter.html
Where is Instrument cluster Light Fuse located on 1996 Honda Accord?
http://schematicsdiagram.blogspot.com/2011/12/where-is-instrument-cluster-light-fuse.html
These details will help.
Thanks.
Sony 6060F blown fuse
hello!
there is a standard procedure for proper replacement of blown fuse: CRT TVs: unplug degaussing coil, replace blown fuse with 2amp fuse and turn on the set. If it works, reconnect degaussing coil, replace the fuse with correct value(5-8) amp, depends on model(see fuse note next to holder). Enjoy the show! If in a process of replacing the blown fuse with 2amp w/o degaussing coil it blows again, forget about the next step. Set need repair. It could be an easy one, replacing 1 or 2 shorted diodes or bridge rectifier, but could be real piece of work if the power supply got "fried". If your knowledge won't go further, than fuse replacement, I'd recommend local TV repair shop.
good luck,
Alex.
2answers
I bought my car used from someone and it didnt come with the owners manuel and the cover of the fuese box is missing so i need to know which fuses r wich!! plz help
REPLACEMENT
  1. Locate the fuse for the circuit in question. NOTE: When replacing the fuse, always use a replacement fuse of the same amperage value. NEVER use one with a higher amperage rating. On some vehicles, you may have to remove a cover for access to the main fuse block 88256p51.jpg
    The fuse panel cover has a label with the fuse designations on it 88256p52.jpg
  2. Check the fuse by pulling it from the fuse block and observing the element. If it is broken, install a replacement fuse the same amperage rating. If the fuse blows again, check the circuit for a short to ground or faulty device in the circuit protected by the fuse. Locate the fuse which needs to be checked . . . 88256p53.jpg
    Fig. 1: Fuse locations and component identification 88256g71.gif
    Fig. 2: After you pull the fuse from the block, check the element 88006p42.jpg
    Fig. 3: Visual examination will reveal a blown fuse, but it should not be replaced until repairs are made 88006g76.gif
  3. Continuity can also be checked with the fuse installed in the fuse block with the use of a test light connected across the 2 test points on the end of the fuse. If the test light lights, replace the fuse. Check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
7helpful
2answers
2002 Mercedes C320 wagon / fuse for cigarette lighter
Just did this on my 2002 C320. The blue 15 amp fuse is located in the front fuse box under the hood. It is either #47 or 48. If you already opened the driver-side fuse box, see if the paper fuse map is still there. If it is, find the fuse to be sure. Replacement is very easy, but there is a fuse puller tool in the spare tire well where your kit of replacement fuses should be. if you are in luck and you have a replacement, use the puller tool and replace the fuse.
Open Questions:
See all Sony STR-DE525 Questions
Top Sony Audio Players & Recorders Experts
Marvin
Marvin
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
