Question about Lexmark X7170 All-In-One InkJet Printer
One or more cartridges are not in the correct type or are installed in the incorrect carrier.
4 Related Answers
gremlin11
gremlin11
  • 78 Answers
SOURCE: Clear Carrier Jam + Right Cartridge Incorrect
aussie_jay09,
If your printer is brand new, just out of the box, than repack the printer back in the box and march it right back to where you purchased it from. Your printer is classed under manufacturer criteria as DOA, which means dead on arrival. It is nothing you are doing, the printer is simply faulty and needs to be returned to your supplier for exchange. It happens sometimes and I am sorry you are on the receiving end.
To be more technical about it, from what you are saying it sounds as though you have a faulty print mechinism. This is the central core part of the printer and I have seen this issue on many occasions.
Gremlin11
Posted on Dec 11, 2008
Rakesh Kumar
  • 296 Answers
SOURCE: Cartridge incorrect
Hi, well first of see whether the cartridge is correct or not and second thing is to see if you have installed the correct way. And try to reboothe printer and ses if problem is fixed or not.
Thanks!
Posted on Aug 02, 2009
tbirdfan1
Michael Thomas
  • 3053 Answers
SOURCE: MESSAGE SAYS RIGHT CARTRIDGE INCORRECT
Hello there:
what this is refering to is that the cartridge is either not the right one for the printer or the device is having a problem with that cartridge i would remove the cartridge and verify that it is the right one that goes in their and also since youare having the cartridge out i would clean out the contact area to get rid of the old ink that may be sitting on the contact areas ok
best regards Michael
Posted on Nov 23, 2009
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Lexmark X6570 printer cartridge black
    The Lexmark X6570 printer uses these cartridges: - #41, #41A, #42, #42A, #43XL, #44XL
    Follow the steps below to fix the problem: 1. Remove the print cartridge that is indicated and close the cartridge carrier lid. 2. Close the scanner unit. 3. Disconnect the power cord from the electrical outlet. Wait a few seconds. 4. Reconnect the power cord to the electrical outlet. 5. If the power button is not lit, press it to activate. 6. Reinsert the print cartridge and close the cartridge carrier lid. 7. Close the scanner unit. 8. If the error reappears, then it could be a faulty cartridge. Replace the print cartridge with a new one, close the cartridge carrier lid, and close the scanner unit.
    Posted on Aug 01, 2011
    Is there an auto correction feature
    The key to the right of the spacebar with the "X" printed on it is the correction button. You just place the carrier on the character to the right of the wrong one and hit the corr. button. The carrier should automatically back up and and remove the incorrect character and if you hold the key down it will continue to back up and remove characters. then you just type in the right one(s). Of course you have to have good "correctable" ribbon and correction tape cartridges installed. If the tapes are old you may have to advance them by typing and correcting or by manually advancing them before they will work. If the correction doesn't remove all the ink from the paper you may have a bad ribbon and/or correction tape.
    Sep 17, 2015 | IBM Wheelwriter 3500 By Lexmark Electric...
    Wont see new cartidges
    hello,
    Check whether you installed the cartridges correctly.
    Turn off the printer and open the cartridge compartment.Make sure:-
    • The black cartridge goes to the left carrier.
    • The color cartridge goes to the the right carrier
    • The transparent paper at the bottom of the cartridges is removed before installing them.
    • The cartridges are securely fixed.
    • The scanner unit is closed after installing cartridges.
    Hope this helps.Thanks!
    Sep 27, 2011 | Lexmark X7550 InkJet Printer
    Lexmark X6570 printer cartridge black or colour not recognised error 005, they are correct cartridges, contacts are clean, will not print test page, used diagnostic tool and quote: incorrect cartridges,...
    Jul 28, 2011 | Lexmark X6570 InkJet Printer
    The Lexmark X6650 gives an error: Right cartridge incorrect. This is a new original cartridge I've just installed. The electronic part on the printer is clean and the electronic part on the cartridge...
    1. Remove the print cartridges, and close the cartridge carrier lids.
    2. Disconnect the power cord from the electrical outlet.
    3. Reconnect the power cord to the electrical outlet.
    4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
    5. Reinsert the print cartridges.
    If the error does not reappear, the problem has been corrected.
    If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to determine which cartridge is not working properly.
    5. Reinsert the black (or photo) print cartridge.
    6. If the error:
      • Reappears, replace the black (or photo) print cartridge with a new one.
      • Does not reappear, reinsert the color print cartridge.
    7. If the error reappears, replace the color print cartridge with a new one.
    Jul 22, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
    Just tried installing a new photo31 ink cartridge and I am getting right cartridge incorrect message.
    If you are using a photo cartridge, in your case the #31 cartridge, insert that in the left carrier where the black cartridge is. Make sure your color cartridge is inserted in the right carrier to continue printing.
    Jun 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
    How do I install the printer cartrige? I do not have the booklet...
    1. Turn on your printer.
    2. Open the front cover.
    The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
    1. Press the tabs on the cartridge lids, then lift the lids.
    1. Remove the old ink cartridges.
    1. Store the cartridges in an air-tight container or dispose of them properly.
    2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
    1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
    1. Snap each lid closed.
    1. Close the front cover. The front cover must be closed to start a print job.
    1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
    2. Click the Maintenance tab.
    3. Click Install a new print cartridge.
    4. Click Next.
    5. Select the type of cartridge you installed.
    NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
    1. Click Next.
    Dec 17, 2010 | Dell Inkjet 720 Printer
    The type of print head is incorrect. Install the
    yes . put exactly the cartridge that is compatible with your printer , make sure that you are replacing with the one that has the same number on it as that of the previous cartridge
    Jul 07, 2010 | Canon Pixma MP500 All-In-One InkJet...
    Cartridge incorrect
    Thanks!
    Aug 02, 2009 | Lexmark MFP-X3470 All-In-One InkJet...
    Lexmark 2400 has message saying clear carrier then press start
    Good day Sir, Please check the power switch light if blinking.
    • power light blinking slow - printer is out of paper.
    • power light blinking fast - there is paper jam in paper.
    • once, pauses and blinks again - raise the scanner unit, and remove any objects blocking the path of the printer cartridge carrier. Or the print cartridge is missing/ not installed properly. Or the printer cartridge is not the correct type for the printer.
    Have a nice day.
    Nov 22, 2008 | Lexmark X1240 All-In-One InkJet Printer
    Hp psc 2110 incorrect ink cartridge message.
    when ever i get that message it's when i use a "Non-HP" replacement cartridge...try using a HP catridge, or most likely, the printer has reached the end of it's usefull life!
    you can try a "full reset" of the printer by..
    -unplug it and let sit for a little while,
    -BEFORE plugging it back in, press and hold both the enter and cancel buttons,
    -plug the power cord in, and wait to release the buttons until the display on the printer tells you to,
    -in many cases, this corrects some problems (especially that awfull grinding/ratcheting noise).
    after many years of faithful service, i think mine is officially dead though...even the full resxet doesnt help.
    Oct 26, 2006 | HP PSC 2110 Color Printer
    Lexmark X7170 All-In-One InkJet Printer Logo
    265 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Muntejaya Ginting
    Muntejaya Ginting
    CheckitRight
    CheckitRight
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
