Question about Northgate (STAX2517C2) PC Desktop
Wiring diagram for northgate computer
Mother board
Posted by al white on
joecoolvette
  • Northgate Master
  • 5,660 Answers
You didn't state the model number, unless that is it in the problem heading, STAX2517C2.
IF, this is the Model Number of the Northgate Desktop PC, it is supposed to come with a Foxconn/Winfast K7S741MG-6L motherboard,
http://www.ebay.com/itm/STAX2517C2-Winfast-Foxconn-AMD-Motherboard-K7S741MG-6L-/380384605182
Click on the photo with SOLD across it. On the next page scroll it down.
There is a main view shown, and separate views under it.
In the separate views, click on the third one from the Left.
http://www.motherboards.org/imageview.html?i=/images/mobot/motherboards/8286.jpg
Looks like the Front Panel header on the motherboard, is an 9-pin unit.
(Down by the round CMOS battery, black plastic rectangular header, 9-pins.
In the photo it is down to the Bottom/left corner )
[ The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
May be an abbreviation silk-screened on the motherboard next to it.
F PANEL 1, or FRP1, or FP1 ]
Motherboard sitting in your computer case, the Front Panel header is sitting Horizontal, and parallel to the bottom edge of the motherboard.
There are two rows of pins.
4 across the Top row; 5 across the Bottom row.
The best method is to take an LED light with two wires, and touch two contact pins at a time.
I would go across the Top row first.
Start with the first two pins. Then the second two pins.
When you touch the correct two pins, the Power Supply will come on.
(So will the computer)
You now know that this is the two pins for the Power On switch.
Computer running do not touch the two pins again.
Now touch two other pins.
When the LED light blinks, you know you have the HarDDrive activity LED pins.
If the LED stays on you have the Power On LED pins.
If the computer restarts you know you have the Restart switch pins.
This is what I have that seems to be close, for a Front Panel header pinout for your motherboard.
HOWEVER, I would like you to connect the two pins to the Power On switch first. Just those two.
If these are correct there is a 99 percent chance the others are too.
A) Using an LED light will not harm your motherboard. If the computer isn't running, (Power Supply not on), then you will not be touching any 'live' pins on the motherboard.
Just make a brief contact, with the wires to each set of 2 pins. The Power On switch is a Momentary Contact Switch.
Pinout I have;
Looking at the Front Panel header - Top row;
Starting at the Left side, coming across to the Right side;
Pins 2, 4, 6, and 8. Blank spot -> No pin.
Bottom row;
Starting on the Left side, coming across to the Right side;
Pins 1, 3, 5, 7, and 9.
A) Pins 2 and 4 are for the Power On LED (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
B) Pins 6 and 8 are for the Power On switch.
C) No pin 10. Blank spot.
D) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
E) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
F) Pin 9 is N/C. Not Connected. Probably 5 Volts (DC), and reserved for the factory.
Would appreciate hearing back if this pinout worked for your motherboard.
Also would appreciate if it did not work, and you found out, how about posting back on that also?
A LOT of people would appreciate this information.
Regards,
joecoolvette
Posted on Aug 08, 2012
When i press power switch, mother boards power became off.
mother board problem.. u have to change ur mother board or u can do 1 thing just open the restart connection.form the mother board.
Mar 29, 2011 | Intel D845GVSR Motherboard
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
ASUS P5S800-VM mother board V Asus EN9500GT graphic card
you would need a new mother board or change the graphics card
Feb 11, 2009 | ASUS P5S800-VM Motherboard
Mother board problem
what processor do you have? send a specs
Feb 09, 2009 | Computers & Internet
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Mother board cd
Your motherboard number is often printed on the board itself.
Jun 24, 2008 | Computers & Internet
Processor for P5VDC-MX
Hey there alcouto, your motherboard supports Intel Celeron, Intel Pentium 4, and Intel Pentium D processors. The socket set is LGA775. The FSB should be no higher than 800Mhz. It appears you have purchased the wrong CPU for your board. I hope the rest of the info helps you on your next purchase. Good Luck!
Jan 29, 2008 | ASUS P5VDC-MX Motherboard
Northgate (STAX2517C2) PC Desktop Logo
113 people viewed this question
Top Northgate Computers & Internet Experts
Ekse
Carlo Barzo
Carlo Barzo
Tom Chichester
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
