Question about JVC KD-LH1100 CD Player
JVC KD-LH1100 power cuts out when volume is too high
Installed aftermarket 6x9 speakers. now the power cuts out to the head unit when the volume is higher than 20ish
Posted by ICantFixEverythin on
Brian
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Sounds like a bad ground.
Posted on Aug 08, 2012
  • ICantFixEverythin Aug 08, 2012
    thats what i thought when i searched a bit more. if the speaker bracket is touching metal is that grounding the speaker? because one speaker is a tight fit and the bracket is touching the metal.
  • Brian
    Brian Aug 08, 2012
    I think you need to find a better ground for the head unit. As long as the speaker connectors aren't touching the metal, you should be fine.
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
informatica
Greg Cann
  • 1114 Answers
SOURCE: how set time jvc kd g220
Hi - You can download the manual from the link underlined in blue below:
jvc kd g220
See page 10.
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 21, 2008
Anonymous
  • 3 Answers
SOURCE: problem downloading
Follow this link to the how to instructions.
http://www.jvc-victor.co.jp/english/car/download/2004/pict/howto.html
Then go the next link and download the (Image Converter wide 1.2), version, now remember it takes time to load onto your player, 90 frames might take 4 minutes. I’ve done this and it works but you have to set your player settings to user options it helps to have the Instruction manual handy.
http://www.jvc-victor.co.jp/english/download/imgconv_patch/imgconv_dl.html
Instruction manual is at this link.
http://support.jvc.com/consumer/product.jsp?modelId=MODL027164&pathId=87&page=1&archive=true
Posted on Nov 12, 2008
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
Anonymous
SOURCE: Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
Posted on Jul 19, 2010
Aftermarket speakers stoped working
Can a head phone be plug into the unit and if so - can you hear sound over the head phone. Also first look if nothing is stuck in the head phone jack (where it is plugged in as kids tend to stuff small objects into it). If sound can be heard over the head phones the unit is ok. The problem then lies with in the speaker output circuitry. The speaker output wiring has most of the time a inbuilt fuse that protects the circuitry when the speaker wires are shorted out when power (volume) is on. The unit has to be opened to replace it by a knowledgeable person.
Nov 28, 2017 | 2003 Ford Explorer
Need to find a wire harness to in my radio does not have to on that goes from radio to car harness. where can i find on for a JVC model KD-LH1100
Car harness adapters can be purchased in Best Buy or Crutchfield just give them the make & year of your car. Try Metra and call to see if they still make Universal harnesses for JVC so you can connect it to a universal harness to your type of car. Just click them together to avoid soldering or taping with electrical tape.
I use to work for Circuit City Roadshop and they(METRA) only made it Exclusively for Circuit City and nobody else in 2008.
Apr 09, 2010 | JVC KD-LH1100 CD Player
Ive got a jvc kd g140 and it cuts out at high volume.
did you hook this head unit up or did you have some one hook it up for you? most of the time it is that factory amp that makes it cute in and out. take the head unit out of you car and hook it up with a 12 volt power in your house or on you battary with a speaker and if it still cuts out the amp chip need to be replaced. let me know if this helped. thanks.
Kim ( Owner )
KS AUDIO
www.ksaudio99.webs.com
[email protected]
Jan 15, 2010 | JVC KD-G140 Car CD Player
Had this for s580 for the last 5 yrs...the other
Check for output at the rca jacks,try the radio.Unit this old may need the power amps(s),is unit used mostly at high volume?, replaced,may not be worth the cost.
Sep 07, 2009 | JVC KD-S580 CD Player
Have just installed (per instructions) a jvc car cd KD-G386/KD-G385 receiver in my caravan, nothing seems to operate, have reset it. and press "display"button-clock comes on for couple of seconds...
Hi colinelva.
I can probably help you but I need more info.
Lets start with the vehicle, What year ,? What specific model?, What type of head unit came out? Was it factory?
Did you use a wiring adapter, or just cut the plug off and hardwire it?. If so give me the color code of all the wires that you used in the dash. are their any left over but not hooked up? How many speakers? All Factory?
I don't need any info about the JVC Head unit.
Lets start with that, and we will take it from there.
Regards, Paul
Jun 13, 2008 | JVC Car Audio & Video
Only bass coming through speakers
Nevermind, the unit fixed itself... i dont know what happend...
Mar 07, 2008 | JVC Arsenal KD-AR3000 CD Player
No bass in my car
if it a 6x9 they is no miracle to it speaker blown cheers
Jan 07, 2008 | JVC KD-HDR1 CD Player
My l/o works but my speakers running from head unit does not
You have to find the subwoofer setting on your head and turn it all the way up.
Aug 26, 2006 | JVC KD-G320 CD Player
JVC KD-LH1100 CD Player Logo
122 people viewed this question
Top JVC Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
