Question about Sanyo EasyStreet NVM-4370 Car GPS Receiver
How do I change the language and voice for NVM Sanyo C9Y4 to English.
Masda radio sanjo C9YO4
5 Related Answers
Anonymous
SOURCE: Can't change .wav files on Sanyo NVM-4370 GPS
More than likely the file you saved is in a different format versus the original; for example, in 16-bit stereo (2 channel) format as opposed to 8-bit mono (1 channel). You'll have to find out what format the originals are in then save your modified files in the same format.
Posted on Feb 09, 2009
KhaKev
  • 20 Answers
SOURCE: How to add music and video files to the sanyo nvm-4370 gps system
Option 1 (Internal Memory):
  • Connect the GPS to your computer with a supplied USB cable
  • For Windows, go to My Computer and find the connected drive (Removable Disk), when you open this disk you should see MobileNavigator folder
  • From the root of this drive, you can create 3 folders: Photos, Music, Videos and copy your media files respectively
  • Safely Remove Hardware the connected unit and unplug
  • Select your player/viewer (Photos, Music, Videos)
  • By default the internal memory (a can shape icon) is selected
  • Now enjoy your media
Option 2 (SD Card):
  • Assume your computer has a SD card reader
  • Insert the SD card to your computer
  • Insert the card to the Sanyo GPS
  • Tab the internal memory option (a can shape) to change to SD card option (sd card shape) to access files on SD card
Posted on Mar 05, 2009
KhaKev
  • 20 Answers
SOURCE: my sanyo nvm 4370 video option say no video player installed
This unit only supports MPEG4/H.264 file. The files format has to be .MP4. This unit cannot play all MPEG4/H.264 movie files. Most movies out there are converted using DivX or XviD codec so if you need to convert them to this supported format. It will mostly cost you time if you found a free converter.
If you don't have time. You might try my basic hack to add a 3rd party media player that will play almost everything out there and it also supports sub-titles. You can check out my video on YT @ http://www.youtube.com/KhaKev.
KhaKev
  • 20 Answers
SOURCE: How do I change the voice setting on the Sanyo
It's impossible. This unit comes with one voice per language. There are 3 languages, English, French and Spanish.
Langage can be set under Main Menu -> Settings -> Local -> Language.
Posted on Apr 19, 2009
Anonymous
SOURCE: MAP UPGRADE FOR SANYO NVM-4050
September 20th 2009. Just checked the website http://www.easystreetnav.com/ You can purchase a dvd map ugrade here for $79.00
http://www.navigation.com/is-bin/INTERSHOP.enfinity/WFS/Navteq-SanyoNorthAmerica-Site/en_US/-/USD/ViewProductDetail-Start?ProductUUID=iE0KCghBecgAAAEiTzYJ8YH7&CatalogCategoryID=&JumpTo=OfferList
Personaly I think this is BS. There should have been something sooner and way cheaper. A lot of bells and whistles but sorely lacking support and not all that great over all. Id be happier with better navigation then backup camera's and "fm" transmiters.
Posted on Oct 21, 2009
Flyback transformer number of sanyo tv model ST-21g1
thats a very old crt tv try sanjo website for parts but i think a line timebase/flyback transformer for that model will not be easy to find
Apr 05, 2018 | Sanyo Televison & Video
My sanjo tv has sound but no picture
If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 04, 2017 | Televison & Video
How do i change Sanyo C9Y4 Language from Japaness to english
It will come up with option, s in settings or set up.in manual.
Oct 27, 2014 | GPS
Inside door latch broken on my Sanjo microwave EMD9552
Hi, For any repairs involving door latches on microwave ovens, I strongly urge you to get a certified service technician to replace and adjust the door for you as he should have a leak detector to verify the fix. Not performing the leak test could expose you/your loved ones to harmful microwave energy if not setup correctly
Dec 08, 2012 | Sanyo Microwave Microwave Oven
My masda 2 radio keeps blowing any suggestings iv changed the fuse but did it again
uve defo got a short somewere one of those process elimanation jobs one solution is to put a bigger fuse in to see how bad the short is tho would only recommend u do this to see how bad short is wouldnt recommend u leave a overated fuse in even if it dosent blow doing this could cause damage to ur wiring or worse a fire or if u no someone with bit of knoledge get them to bell all the circuits and wires out if no luck there unfortanatly ur short will be in the radio unit big headacke good luck hope this helps a bit
Mar 24, 2012 | Cars & Trucks
By mistake the language has been changed, how do I change the language of Garmin back to english?
  • On the page that shows WHERE TO and VIEW MAP press TOOLS (the spanner symbol at the bottom right corner)
  • Press SETTINGS (The spanner symbol) or LOCALE (The blue symbol) on models that don't have a settings icon
  • Press LANGUAGE (the lips symbol)
  • There are 3 items on this screen; VOICE, TEXT LANGUAGE and KEYBOARD
  • To change the voice language to English press VOICE and select an English speaking voice
  • To change the text language press TEXT LANGUAGE and select English, or American English if you're in the USA
If the text language is already in German you probably won't know which is voice, text and keyboard. The German word for German is Deutch so when you see this beside one of the items you'll know this is the one to change the text language. This should solve your problem.
Jan 29, 2011 | GPS
Change languge to english on garmin 255w
  1. Press TOOLS (the spanner symbol in the bottom right corner of the WHERE TO and VIEW MAP screen)
  2. Press SETTINGS, the spanner symbol (Or LOCALE if your model doesn't have settings)the blue icon
  3. Press LANGUAGE (The lips symbol)
You will see a screen with 3 icons; VOICE, TEXT LANGUAGE and KEYBOARD
  • To change the Voice language press VOICE and select an English voice.
  • To change the Text Language, Press TEXT LANGUAGE and select English, or American English if you're in the USA
All should be back to English now.
Oct 14, 2010 | GPS
How do I change language on Garmin Nuvi 750?
  1. Press TOOLS (The spanner symbol on the screen that shows WHERE TO and VIEW MAP)
  2. Press SETTINGS (The spanner symbol)
  3. Press Language (The lips symbol)
  4. There are 3 items on this screen VOICE, TEXT LANGUAGE and KEYBOARD
  5. If you need to change the voice to english press voice and select an english voice.
    If you need to change the text to english press TEXT LANGUAGE and select english
Oct 02, 2010 | Garmin nuvi 750 GPS Receiver
Sanyo EasyStreet NVM-4370 Car GPS Receiver Logo
370 people viewed this question
Top Sanyo GPS Experts
Marvin
Marvin
Tom Chichester
Are you a Sanyo GPS Expert? Answer questions, earn points and help others
