Question about Kia Vehicle Parts & Accessories
How to put spark plugs in car
How to put in car
Posted by clinton on
George Agios
    Sergeant:
  • 220 Answers
You have 4 black wires6 milimeters top of your engine take 1 of fit one in then 2nd comblete 3th and 4th you need spark plug socket go an clock wise. check the gap.
Posted on Aug 09, 2012
Richard Brooks
    Sergeant:
  • Kia Expert
  • 242 Answers
The solution George gave you is unsafe,not enough info and misspelled..But he does have the right idea...If you don't have the parts yet be sure and inspect the plugs for shipping damage before you leave the store..(I have seen some new plugs that are cracked,broken tips and damaged threads and you don't want to see that after you get home and if you install a damaged plug it could do more damage to other engine components..)..get some hand cleaner,spark plug boot lube,2 very small packs of anti-seize,safety glasses, rubber gloves.(I assume you have the correct tools..If not you better get a good 3/8 ratchet 9 inch extension/3inch extension and a good spark plug socket that fits your certain plug..Be sure the socket has the rubber inside of it to grip the plug so you will be able to thread the plug in by hand without it falling out of socket or getting it cross-threaded....Get the parts clerk to gap the plugs unless you want to do it..they will come pre-gapped but no one can trust that..Get home, park car ,set park brake,raise hood an let engine cool down.Get safety glasses..Disconnect negative battery cable in case you drop a tool hitting the alternator or something else that could spark and cause a fire..Begin....Remove first plug wire..twist boot left to right while pulling at the same time..(Spark plug wires are easy to come apart...be careful.)...remove wire ,blow air into plug area before removing plug to remove contamination /particles...remove plug..inspect plug for irregular wear and discoloration..(I can tell you what makes the plug look good or bad but without knowing Telling you all of them would take awhile..) get new plug and lightly coat threads with anti-seize..install plug into special socket,make sure it won't fall out..use extension..,slide it in to position and slowly turn clockwise..watch and hold it straight as possible.apply a little downforce..keep turning until you can tell it is in place tighten to about 18lbs to 20 lbs..(Tight but rather a tight snug..)..DONT OVERTIGHTEN !!!..rub boot lube inside of plug wire boot and install wire..push wire on with good pressure listen closely for a slight click and 1 is done...Do all the other plugs exactly like the first..connect battery..check for any tools left under hood,start engine and test drive..........Hope this helps.....Brooks/Metalpoet...
Posted on Jun 13, 2014
Went to put gas, after I put gas the car wouldn't
Check that you put petrol and not diesel or visa versa when you refuelled the vehicle.
Jul 15, 2013 | Cars & Trucks
Broken Engine oil Dipstick. Don't know how much oil to put in engine. How many Quarts of engine oil does it need.
if you can't detect oil level or usage, there's no way to determine how much oil to put in the car.
you can drain it all and put in "x" amount of oil. but if it uses oil, think about it, how do you know how much to put in if you can't determine the level.
or put in 2 quarts, go to church and hope it's a german car. The pope, being german, loves german cars now. Therefore jesus does too.
Jun 24, 2010 | Cars & Trucks
I cant put my key in lock position and take out my key from car
Put in park,switch of ignition,turn key one click forward and remove key
Mar 31, 2010 | 1999 Lexus ES 300
Put put put put put put!
Change the coil pack..Common problem with the cleo.
Jun 06, 2009 | 1986 Renault Sport
PUT IN NEW STEREO NOW CAR WON'T START & SECURITY LIGHT IS ON
the radio that come with car is program to pcm .if remove or put in another radio. pcm security mode kick in.it dont recognize radio it think theft so it disable car ignition so you cant start.if you get a radio the dealership has to put them in and program it.
May 31, 2009 | 2001 Chevrolet Venture
Car will not let you take it out of park
put your foot on the brake before you attempt to take it out of park
Robert
Jan 19, 2009 | 1999 Lincoln Town Car
Vehicle Parts & Accessories Logo
90 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Kardoc
Marvin
Marvin
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
