Question about Springfield Measuring Tools & Sensors
Is there an online manual for Springfield 91756 Wireless Thermometer w/Indoor/Outdoor Temperature & Humidity
I need a manual for Springfield 91756 Wireless Thermometer w/Indoor/Outdoor Temperature & Humidity
merryangel
    New Friend:
Yes. Took awhile to find it, but here is the link: https://docs.google.com/gview?url=http://www.weatherconnection.com/manuals/91756.pdf&chrome=true
Posted on Jan 22, 2013
5 Related Answers
Steve
  • 3289 Answers
SOURCE: The outdoor temperature & hygrometer
Hi Walter,
I found this in the manual, simply pressing the RESET button won't start communication again. Try this:
Your main unit displays current, minimum, and
maximum temperature and humidity readings
collected by the remote sensor and main unit.
Outdoor data is collected and displayed every
40 seconds and indoor data is collected and
displayed every 10 seconds.
The red LED flashes whenever the sensor
transmits an RF signal to the receiver.
select sensor or use auto scan
• Press CHANNEL to switch between
sensors 1-3.
• To auto-scan between sensors, press and hold
CHANNEL for 2 seconds. Each sensor's data
will be displayed for 3 seconds. To end autoscan,
press CHANNEL or MEMORY.
• Press and hold CHANNEL and MEMORY
simultaneously to search for remote sensors.
resetting the system
The RESET buttons are located on the back of the
main unit and sensor. Use a pointed subject to
press RESET when you change the batteries and
whenever the system malfunctions.
Posted on Jul 13, 2011
Anonymous
SOURCE: i put new batteries into both units, the indoor
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Posted on Oct 18, 2010
Greg McCarthy
  • 1340 Answers
SOURCE: Need to know exact frequencies
When on channel one,hook up an oscilloscope to the channel output circuit on the output terminals.First read channel 1,then channel 2,then channel 3.You can leave the oscilloscope hooked up the whole time.Start on the highest available scale,then work your way down scale by scale until it is accurately readable.Then you will need to find the input to the counting circuit,most likely from a thermistor.You will need to reconfigure the counting circuit to send a signal from what the thermistor is reading for the temperature to 600Hz instead of what the current counting circuit is set at.You can achieve that by connecting the oscilloscope to the output side of the IC for the counting circuit with one lead on the output,one lead on the input,and determine what it is set at currently,then redesign it to pulse at 600Hz input which is 10 second intervals.Greg
Posted on Oct 30, 2010
  • 6113 Answers
SOURCE: Need set up manual for The Weather Channel indoor
The manual for the thermometer is available on the LaCrosse site: http://www.lacrossetechnology.com/7034twcit/index.php . The direct link is http://www.lacrossetechnology.com/7034twcit/manual.pdf .
Put the batteries in the remote(s) first. (If you need to reset the units, pull the batteries from the indoor temperature sensor and the remotes for 10 minutes before restarting.) With the remotes and indoor sensor 3 to 5 feet apart, put the batteries in the indoor temperature sensor. Then wait 10 minutes before pressing any buttons. Once you have confirmed communication between the units, then move the remotes to their final location (not more than 330 feet away minus 30 feet for external walls or windows and 20 feet for each internal wall between the units.)
I hope this helps.
Posted on Jul 08, 2011
billklucas
SOURCE: I have the Acurite 00604RX
how do i set my clock for accurite 00604RX
Posted on Sep 07, 2011
My acurite 00509 has stopped giving me the correct temp reading. I've put another temp gauge next to it and acurite shows 78* and my othergauge shows 72*. Do I need to return it or what ? Thanks
The indoor temperature and humidity and outdoor temperature readings can be calibrated on the display to improve accuracy. Calibration can improve accuracy when sensor placement or environmental factors impact your data accuracy. 1. To access calibration mode, press AND HOLD the "?", "?", and "SET" buttons for at least 5 seconds. 2. Once in calibration mode, the preference you are currently setting will be highlighted on the display. 3. Press the "?" or "?" buttons to calibrate the data value higher or lower from the actual reading. 4. Press the "SET" button to confirm the calibration adjustment. The " " icon will remain illuminated next to calibrated values. 5. The next adjustable data will begin flashing, indicating it is ready to be calibrated. Repeat Steps 1 - 4 to calibrate additional data. The preference set order is as follows: OUTDOOR TEMPERATURE INDOOR TEMPERATURE INDOOR HUMIDITY BAROMETRIC PRESSURE (must be set to MANUAL mode; see page 12) After 20 seconds of inactivity, the display will save the adjustments and exit calibration mode. Note: Calibrations will be erased if the display is reset or if batteries are removed and the power adapter is unplugged.
Oct 02, 2018 | Acu-Rite Acurite Wireless Weather...
Can't get a temperature reading on my Springfield 91756 thermometer even after changing batteries. Just get - - -.
The batteries in the outdoor unit have to be changed first and time allowed for it to begin transmitting. If you are in a very cold location, the batteries may may decline in efficiency to a point where the outdoor unit can't transmit. In this case, you may find that the temperature reading returns in warmer weather.
Feb 23, 2015 | Springfield 91751 Digital Rf Weather...
Springfield precise temp in out thermometer 91756
Return it to the manufacturer for warranty repair/replacement
Jul 23, 2014 | Taylor 91756 Wireless Thermometer With...
Instructions for springfield precise temp model 91455
I also reset my 91455 today. Go online to Springfield precise temp manual 91455
May 29, 2012 | Springfield 91455 Wireless Digital Outdoor...
My model is 91756 and i need to buy a remote sensor wire in Mpls mn
After 3 months and 4 emails to Springfield they finally responded and told me to buy my probe on Amazon. I can't find one on Amazon, do you have any suggestions or know of where I can purchase one?
Nov 17, 2010 | Springfield 91455 Wireless Digital Outdoor...
BIOS Digital Wireless Thermometer 312BC SETUP INSTRUCTIONS
I have a BIOS wireless indoor/outdoor thermometer. The indoor base unit doesn't display the outdoor temperature - it is blank - however the other temperatures - humidity, indoor temp, etc., are displayed, What is the problem? We have misplaced the manual so we don't know what to do.
Aug 28, 2010 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
3,017 people viewed this question
Top Springfield Measuring Tools & Sensors Experts
Harrie
Andrew Taylor
Andrew Taylor
Are you a Springfield Measuring Tool and Sensor Expert? Answer questions, earn points and help others
