Question about Copystar Kyocera Taskalfa 181 Copier
Kyocera taskalfa 181 call for service c0130
I get an error on the screen " call for service c0130 "
Posted by Louis Botha on
Leroy Elliott
    Fixya-Fanatic:
    Visited the website for 90 consecutive days.
  • Copystar Master
  • 424 Answers
You need a technician to update the FIRMWARE
Posted on Mar 14, 2019
Tom Chichester
    Top Expert:
  • Copystar Master
  • 55,375 Answers
Soo...Call for service
Posted on Oct 23, 2017
The CE code is showing on screen
Communication error
If communication between the ignition board and the display board is not established
within 3 s of power-up an error will be displayed. After communication is
established, if it is lost for 30 s, the error will be displayed. The error code will
be cleared upon a valid data exchange between boards.
May 18, 2012 | Hayward H-series Electronic Gas Pool...
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Camera not working
the main problem may be that either the camera is damaged or any circuit to the camera is broken...
i'll suggest you go to your nearby samsung service centre and fix it for free (if under warranty)
Dec 01, 2011 | Samsung SGH-G800 Cellular Phone
The orange "Alarm" light keeps
AP position error will trigger a 6A00 error code. An error occurred in the AP motor during purging operation. According to the service manual you will need to replace the sheet feed unit, logic board assy, purge unit.
Feb 22, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I had Dell Windows XP along time ago. I now have Windows Vista Business and I think it is Service pack 1. I pressed F12 and did diagnosis then it scanned right off the bat it says... "Error Code...
Hi. Error 0146 is pertaining to a failing hard drive. You can still try to reinstall Windows Vista by requesting for a CD from Dell by contacting them.
If they fail to send you a CD or if the error still comes up after reinstalling Vista, then you need to replace your hard drive.
Feb 06, 2011 | Dell Inspiron 1501 Notebook
Printer error :"49.C02 service error " message
i think this caused by your windows is not genuine
Jan 14, 2011 | HP LaserJet 4700 Printer
Copystar Kyocera Taskalfa 181 Copier Logo
215 people viewed this question
Top Copystar Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
