All keys didn't response by pressing include ON/OFF. I can get incoming call by open slider but i can't dial.
SOURCE: How do you get rid off 'emergency calls only'?
turn the phone off and then back on. That usually solves it. Or take out the sim card,wipe it off, put it back in, and turn the phone back on.
SOURCE: keypad not working
you will need to take the case off the phone and check behind the buttons where the pads touch the circuit board these sometimes get greasy or dusty causing it to not create a conection between button and the circuit board clean the circuit board with dry dust free cloth look for signs of grease or water damage if this is clean or after cleaning put phone back together and try buttons if they still dont work you could try replacing the keys that you press as sometimes after alot of use these fail to connect with the board properly causing buttons not to work if you replace these and still dont work then it could be a warped board this happens if you have sat on phone or had it in pocket and let on something causing pressure on the case and this will warp the board their is no cure for this the only thing to do is buy new phone as a new board will cost as much as the phone hopefully this is not the case it might just need your keypad replacing try my first two sollutions first if this dont change anything then i would take it to repair shop and see if they think it is a warped board hope this is some help to you
SOURCE: Keypad doesn't seems to work - seems locked - gets incoming calls
JOSE18
under tools there is a record option. erase all things that have been recorded. the button on the top screen on the right hand side allows you to record phone calls. You have probably been hitting it on accident and recording calls and such. Let me know if this works.
SOURCE: how to unlock samsung gt c3053 mobile phone
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong network SIM and insert a half of it,
so it won't ask for network password and shows "Insert SIM" message.
Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.)
3.With out turn off the phone push the sim fully in. At this stage the phone is still asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
(star 7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable network lock By typing: #7465625*638*00000000#
(hash 7465625 star 638 star 8zeros hash)
Phone is unlocked (check with *#7465625#)
