Does not slip. Have replaced the release mech and holder. It is setup and triple checked by the book
SOURCE: the clutch in my bike keeps slipping i have replac...
since you already installed your new clutch, now you just need to have it adjusted
SOURCE: The bike will go in gear but the clutch won't
Remove clutch slave cylinder & push piston right in then refit
Ride safe
Bike-Doc
SOURCE: clutch won't release
Start with inspecting the clutch handle for any obstructions or rust.
Lubricate the clutch cable at the handle.
Follow the cable down and look for and pinching or damage.If you can follow the end of the cable to the actuall clutch mecaniism, inspect the area for clearance.
If you can disconnect the cable from the clutch mecanisim and test the clutch handle to see if the cable moves freely.
Manually try to engange an clucth with the engine off.
If it won't move, time to diassemble the clutch.
