SOURCE: NEFF oven U1461 - The bottom oven door hinges do
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Please rate my solution.
Thanks.
SOURCE: on the NEFF u1461 how
Pair of pliers on the old knob (make sure it is in the off position) and a hefty tug. The new one will push on by hand, push it all the way in so it is flush to the fascia and then click it to check the pop out mechanism works ok. The knob is a D shaped fitting with the flat part of the D at the top.Hope this helps. You may find when you tug at the old knob, the cover comes off and you are left with the black portion still in position, if this happens, reposition the pliers on the protruding black lug and give it another pull, this will get out the remaining part of the knob.
