D-Link GamerLounge DGL-4300 Router (DGL4300) Logo
Posted on Aug 07, 2012
Reset password on the log on screen for set up, how do you reset the password. user manual states by default there is no password, this is not working
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Aug 07, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
1724
Points
21
Try from Online sites..
1 Related Answer
Anonymous
  • 103 Answers
  • Posted on Nov 09, 2009
SOURCE: I can not install DLINK Wireless G Router, have
Maybe you did a soft reset, try a hard reset by holding down the reset button for 60 seconds, unplug it for 10 seconds, then plug it back in. See if that helps. IF you cannot log on, try putting password as admin leave username blank.
Testimonial: "Thank you, I went through the steps a number of times before it responded and eventually allowed me to complete the process."
Ricoh aficio mp 2000 can't print asking for log in username and password?
Login Issue Assistance
User
I never set any log in details, I have tried Admin,Supervisor with a blank password but not working, please assist
ChatGPT
If you're being prompted for a login username and password on your Ricoh Aficio MP 2000 printer and you haven't set any login details before, there are a few things you can try:
Default Login Credentials: The default username and password for Ricoh printers are often set to "admin" for both the username and password. Try using "admin" as both the username and password to see if it works.
Factory Reset: If the default login credentials don't work, you can try performing a factory reset on your printer. This will reset all settings, including any login information that might have been set. However, keep in mind that a factory reset will also erase any other custom settings you have configured on the printer. To perform a factory reset, you can refer to the printer's user manual or contact Ricoh support for specific instructions.
Contact Ricoh Support
1helpful
Restore my Mx-b382 setting to factory setting
Probably you can access the settings through the operation screen on the machine.
There you may find this reset setting.
I found a manual here:
https://www.sharp.eu/cps/rde/xbcr/documents/documents/om/34_ppc/MXB382-SC_OM_Start-Guide_GB.pdf
There in it says:
Factory default passwords
When accessing the system settings, the administrator password is required to log in with administrator rights. The system settings can be configured in the Web pages as well as on the operation panel. To access the system settings using the Web pages, a password is also required.
Factory default administrator password is “admin”
Store a new administrator password as soon as the machine is installed.
Once the administrator password has been changed, the new password is required to restore the factory default password. Take care to remember the new password.
Factory default passwords (Web pages)
There are two factory default accounts: "Administrator" and "User". A person who logs in as an "Administrator" can configure all settings in the Web pages. In addition, an administrator can restrict access to other settings by enabling "User" accounts.
Default:
users with password users
admin with password admin
If this has been changed when the machine was installed you have a challenge to find out who changed it and if this person still knows it.
2answers
How do I recover from forgotten admin password?
Some routers have passwords printed on the bottom. Most routers use "admin" as username, and then either default password or unique password. In any case, read the user manual, you should find it there. Download Free Manuals
4answers
I cant log i i changed name / pwd and forget it. i had it unplugged for a year but still cant log ijn how can i reset pasword or retrieve log in info?
Please provide more information as to you issue such as :
a. model number
b. year manufactured/firmware updated
c.Are you using router wirelessly or hard connected.
d. You have checked the user manual 1st.
e. You have confirmed that you have connectivity with the ISP ( internet service provider)
f. uninstall/ reinstall the router software with the CD provided from the manufacturer.
How do i change a password
If you don't have the current password, you will have to press the reset button located next to the power connector port. This will reset it back to factory default settings. The you can access it with your browser:
To access the Web-based management utility:
1 Open your Web browser and enter the IP address of the router into the
Location (for Netscape) or Address (for Internet Explorer) field, then press
Enter. The default IP address of the router is 192.168.0.1
For example, type 192.168.0.1
After the connection is established, the logon screen opens.
2 To log in as an administrator, enter the user name of admin and leave the
password field blank (default), then click OK. The Web management Home
screen opens.
You can download the user manual at:
http://www.retrevo.com/support/Dynex-DX-E401-Routers-manual/id/8352ag821/t/2/
I want to change the settings of my Hawking router WR-258. I don't have a user name and password so I pushed the reset button. But the user 'admin' with no password is not correct. What is the default??
When the Login pop-up for the Router
appears, please enter “admin” for the
username to access the configuration screen.
(Note: By default, there is no password. If
you cannot get in, please reset the router by
pressing the button next to the antenna on the
back of the router and try logging in again.)
Copy pasted from the manual.
Wr850g will not install. Default name/password does not work. The default settings are NOT accepted. How do I get past the log in page?
a user manual is available here http://support.digidave.co.uk/index.php?_a=downloads&_m=get&_i=5 there is a reset button on the back - reset to factory settings to get back to the default username and password
see page 15 of the user manual - link above
I can not remember my password so i can use my wi fi. So how do i reset my password. i can log on to the router can i change it in the settings?
Reset
Pressing the Reset button for 5 seconds restores the router to its original factory default settings.
Log in to the Router
This section will explain how to log in to your router using the following steps:
1. Launch your web browser.
2. Enter the URL http://192.168.1.1 in the address bar and press Enter.
A login screen like the one below will be displayed after you connect to the user interface.
Note: There are three account types, each requiring a different username and password.
• The user account provides limited access to certain configurations (username / password: user / user).
• The admin account can perform all functions
(username / password: admin / admin).
• The support account is for ISP technicians for maintenance purposes
(username / password: support / support).
Note: Passwords can be changed at any time.
3. Enter your user name and password, and then click OK to display the user interface.
Note: This manual has been prepared using the admin user name
Logging into the WURE
try with
http://192.168.15.2
then if you still not able to access it then check in back side of router you find reset button press it for 10 seconds then all settings are defaults.
then try with above ip again,
then if it wants user name type "admin' and password as "admin' or blank or 'password'
then set your router as WEP
then go to wi fi security then set wep key it is your password to connect.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
