Question about Nintendo Wii Fit - Balance Board + Game Console
Can't get Wii Fit Balance Board to Sync
I followed the suggestions for resynching my board, but it still just blinks twice and never syncs. Keeps unsynching the remote. Game is in, new batteries. This board is one of the original ones. Hadn't used it for about three months. Suggestions?
Posted by car2nqueen on
tristan oxnam
    New Friend:
    Problem Solver:
  • 10 Answers
You have a big problem
Posted on Aug 07, 2012
How to configure gameon balance board with wii console
1. You need to put Balance Board compatible game disk in the console.
2. Select Disk Chanell and press Start
3. Remove SD Card slot cover on the console and the battery cover on the Balance Board
4. Press and hold for 2-5 sec the SYNC button on the Balance board. You will see a blinking light.
5. Press the Sync button on the Wii console and after a while you will get non-blinking light.
This will mean that your device is synchronized and you are able to use your Balance Board.
Good Luck!
Don't forget to close back the covers you've removed earlier.
May 23, 2012 | Nintendo Wii Fit - Balance Board + Game...
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
My wii fit board power button not staying on just flashes tryed to sync but still not working
I had the same issue with my wii board; I tried to resynch the board and it did not work. I then decided to put in new batteries and resynch again and now it works. Even if you don't think your batteries are that old try to resynch it with new batteries in the wii board, in case the batteries that you are currently using my not be producing enough power.
Jul 04, 2011 | Nintendo Wii Fit for Wii
When i click the button on the wiifit board to connect to the wii, it connects at a second. then loses connection and wii says it is lost. the button on the board just keeps flashing or goes off
If you haven't already tried to replace the batteries, do this (if you have, this is useful information to include in your problem description :D). If that hasn't worked, you may need to re-sync the board with your Wii.
1. Power on your Wii console (there is no need to power on your balance board at this time).
2. Open the SD card slot cover on the front face of your Wii to reveal the red Sync button on the Wii.
3. On the bottom of your balance board, remove the battery cover to reveal the red Sync button on the balance board.
4. Press the Sync button on the balance board (there is no need to keep it depressed; simply press and release). You will notice the power LED on the power button on the balance board blinking.
5. Now press (and release) the Sync button on the Wii console. After the LED stops blinking, the Sync is complete.
If this does not fix your balance board, it may need to be repaired or replaced. Contact Nintendo and provide warranty information if applicable.
May 04, 2011 | Video Game Consoles & Games
How can i re connect the wii fit balance board to my wii ?
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Mar 16, 2011 | Nintendo Wii Console
How do you sync the wii console and wii fit board
Put the Wii Fit game disc in the Wii and start the game. Then open the small SD Card slot cover on the front of the Wii console then remove the battery cover on the bottom of the Wii Balance Board. Press and release the SYNC button on the Wii Balance Board. The light on the board should start blinking. Afterwards press and release the red SYNC button on the Wii console while the light on the board is still blinking. The light on the balance board will stop blinking and stay on steady once the syncronization is successful.
Mar 03, 2011 | Nintendo Wii Console
How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    My wii fit balance board keeps blinking but will not stay on. batteries are good. cant find my instruction book. what could be my problem????
    follow this
    2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
    3. Open the small SD Card slot cover on the front of the Wii console.
    5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
    6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
    7. The blue light will stop blinking and stay on steady once the syncronization is complete.
    Jul 20, 2010 | Nintendo Video Game Consoles & Games
    We used our wii fit on another wii system. After
      Try these steps!
    Fore more detailed information (including pictures) on how to sync the Wii Balance Board, click here.
    If you are still unable to sync your Wii Balance Board, please call 1-800-255-3700 so that they may assist you further.
    Hope it helped.
    Nov 22, 2009 | Nintendo Wii Fit for Wii
    Nintendo Wii Fit - Balance Board + Game Console Logo
    53 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Ekse
    Muntejaya Ginting
    Muntejaya Ginting
    Lee Hodgson
    Lee Hodgson
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
