Question about Wacom Graphire4 4x5
Cursor shaking cant keep cursor still
Posted by bree_koll on
There's a Tab that pops up with illegible writting, then my cursopr disappears, my screen goes black, and takes forever with shaking my mouse to get screen and cursor to reappear.
you system might have got impacted by malware/spyware. Try cleaning your system/files by running anti-virus or anti-malware [ browser cache].
uninstall unwated program from Control panel.
Hope this will help.
Jul 09, 2013 | Computers & Internet
What causes a PC to lose it's cursor, then the screen goes dark
Restart the computer HOLD the keys CTRL+f11 or f12 depend of your model, mark, and restore to factory defaulty, and try it again.
God bless you
Why does the cursor shake on my graphics tablet?
For me it worked changing tablet mode to : recognition data.
This settings is completelly hidden ( double click the tablet icon and a menu pop up)
Dec 30, 2011 | Trust Computers & Internet
Screen shakes and is blurry
try uninstalling and reinsalling your sytems drivers. Also, check all cables are intact and connected well and none are faullty
Apr 26, 2009 | Computers & Internet
My cursor on my toshiba laptop keeps jumping when am typing, its very annoying to find it on a sentence you did not intend to type on. what can I do?
It's probably a bad contact in your keyboard.
Best think to do is take it out for cleaning.
the service manual should be that one :
http://www.eserviceinfo.com/downloadsm/26242/Toshiba_Satellite%20A20%20Series.html
with a bit of info her:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
you can try to shake it (to if something broken in there), vacuum it (be carefully),
If nothing better think replacement..
Thanks for using fixya…good luck and don’t forget to rate this…
cheers
Jan 12, 2009 | Toshiba Satellite A205-S4617 Notebook
Wacom Bamboo stylus shaky cursor
Ur issue is that the tablet itself can not be above the tower or the laptop. Magnets make it shake. I had that problem to anytime it was by the computer (only above for some reason) or by something magnetic, so avoid that and you should be fine.
Dec 12, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
My cursor keeps freezing and I cannot drag it across the screen. I have to shake it and it takes several times to do this. I have a pc/2 compatible mouse. Do you know what is causing the problem. When...
You may have broken a solder connector in the mouse when shaking it. Try a different mouse, if it doesn't happen with the new mouse you know the old on is the problem.
Nov 10, 2008 | Computers & Internet
Cursor drift
don't us the optic mouse with the roller mouse pad. what is happening here, is the optic trying locate a point. since the pad is not flat and smooth. the optic is doing search (meaning it is constantly looking for a landing point). since it can't fine one, it will draft.
hope that will help
Nov 06, 2008 | Innovera Wireless Keyboard/Optical Mouse...
Skipping and Shaking cursor
I have exactly the same problem as you, my tablet worked perfectly for the first three months and then started to act weird, shaking and skipping screen areas, even if i only touch it with my forearm.
Uninstalling/Re-Installing drivers didn't solved anything, so i started switching my tablet to different usb ports in my pc, and from one to another, the problem got a lot better. It didin't solved it, but works "decent". So, comparing yor experience with mine, it's probably an usb-port problem, rather than the tablet itself i thik.
I will test it in othe computerts to see how it goes
Jul 31, 2008 | Genius MousePen 8x6 (MOUSEPEN8X6)
could be that it is too close to the monitor - radio frequencies interfering -- try to put tablet farther away from wherever it's plugged in...
Feb 15, 2008 | Wacom Graphire4 4x5
Open Questions:
Wacom Graphire4 4x5 Logo
Top Wacom Computers & Internet Experts
k24674
Harrie
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
