Question about Nortel Norstar 16-Line PBX Speakerphone
Alarm: 51-2 - no dialtone-cannot dial out or receive calls
Posted by GFHome on
curlycord
    Scholar:
  • 277 Answers
On of your trunk modules went bad.
In this case -2 is the trunks on the KSU, check all connections reboot phone system to see if issue clears.
Posted on Aug 14, 2012
Why no dial tone. Only static?
Check the phone line were it comes into the house there is usually a point where the phone connection from the the TELCO outside wires connects to the inside wiring.
Remove the inside wiring and test the wiring that is on the TELCO side. If you get dialtone the trouble is in the inside wire. If you don't get dialtone call TELCO
Aug 26, 2014 | Lands Phones
We have a Merlin System, the phones are MLX-10D, we have to dial outgoing calls 3-4 times before the call will go through. Now we're receiving complaints that incoming calls are just ringing and we don't...
Sounds like one (or more) of your lines are out in your telephone system. Each time you press a 9 for a line the system simulates a dialtone to see what your dialing next so it can check it against the automatic route selection table. After it checks, it pulls a line out of a pool group to complete the call. At this point its grabbing a line that is not working on the system.The best way to figure out which ones arent working is to check the lines on the main console by pressing each line button and seeing if it produces dialtone. More than likely(but not allways) its going to be a line problem from your dialtone provider.
Sep 21, 2010 | Lucent Merlin Legend MLX-10D Phone
My phone says check Tel Line
Sounds like your telephone line might be dead. If you have a gray or tan telephone box on the outside of your house you can plug your phone in there to test the line. If you get dialtone then thrers a problem in your house wiring, if you don't get dial tone then the line is dead and you need to conact your telco provider.
Apr 14, 2010 | Uniden DECT 6.0 Cordless Telephone...
I can't get dial tone and can't dial out.
make sure the phone is plugged in. You'll need dialtone first, the other issue will fix themselves once you have dialtone!
Feb 10, 2010 | Lucent 1872 Corded Phone
Can i forward my home phone to cell phone
yes, providing you have that service through your provider. It's typically done by accessing your line and dialing *72 if the service is active you'll recieve a stuttered dialtone. then dial your cell phone number. once you've answered your cell the transfer is established. To deactivate call forwarding, from your home phone dial *73. you should recieve a stuttered dialtone confirming that the foward is off.
Dec 22, 2009 | Lands Phones
No dial tone
plug out the fax... plug in a phone... if still no dialtone... replace phone cable... still no dial tone... call the phone company...
plug out the fax... plug in phone... dial tone heard... bad fax... try to reset fax machine... per instructions... still no dial tone... call repair guy...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 18, 2009 | Office Equipment & Supplies
Lately every call I get I lose and receive a dial tone I am with bell but they say it is my phone possibly a software issue
Well, interesting part is, your phone doesn't create the dial tone sound.
If your call is ending, then you hear the dialtone, I would suspect a problem with a particular tower. If it happens all the time and in multiple areas, then all bets are off.
Nov 02, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Dialtone, but no dialing
Uniden offered a replacement, stating that the base phone was probable beyond repair.
Jun 04, 2009 | Uniden DECT 6.0 Cordless Telephone...
Dialing out
Usually picking up the handset and dialing " 9 " will get you another dialtone and then you dial the number you want. If you receive a busy signal it could mean your system requires another number to dial out or your phone is restricted from dialing out. When you pick up your handset or press the INTERCOM key you should get a triangle shapped light which means you can proceed with dialing your access code for making a call ( 8 or 9 ). Hope this helps, let me know ...Mike
Aug 17, 2008 | Nortel T7316E 2-Line Corded Phone
Can't dial out
Can you hear the tones when you dial? Is there a (tone / pulse dial) switch or programming option?
Jul 02, 2007 | Uniden DXAI4288-2 Cordless Phone
Nortel Norstar 16-Line PBX Speakerphone Logo
229 people viewed this question
Top Nortel Lands Phones Experts
Marvin
Marvin
Rich Barnett
Level 1 Expert
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
