SOURCE: Hi I have a magnum 1000 Jacuzzi pump for my
alot of companies use to have a damper ring on pump shaft which would knock down some of the noise a pump motor made pumps make noise and the bigger the pump the louder the noise if its not vibrating or clunking then its running as it should
SOURCE: jacuzzi magnum force 1hp, pool pump. Motor has very loud noise
most likely the bearings are starting to go.
SOURCE: I have a Jacuzzi Magnum Force pool pump. 3/4 hp.
The other end of the shaft has a place to attach a 7/16 or 1/2" wrench. also, there might be a "Reverse Thread" screw in the center of the impeller that you must remove first.
SOURCE: Leaky 4 HP hot tub pump seal AO SMITH motor, pump
If you have removed the impeller this is what you need.
Part number for your shaft seal is : 37400-0028s
Here is a link to the manual on how to install / remove this seal on this pump:
http://www.hottubs.com/content/pdf/Sta-Rite_Dura-Jet_S377(9-12-03).pdf
Refer to page 9.
This seal can be purchased anywhere on the internet. Just do a google search with only the part number. Many suppliers will come up. If you have trouble, I have a few and can make an E-bay sale for one.
Testimonial: "Thanks, and especially for the link to the manual. This is exactly what I needed. Mark"
