Question about General Electric A1250 Digital Camera
The viewing screen is dark when I go to take a picture. It works when I am reviewing pictures already taken.
The lens powers out, but the viewing screen is dark. Can't see what you are taking a picture of and when you go to review what was taken, it is only a dark screen.
Posted by Patricia Pearson on
Leah12
    New Friend:
You could try and connnect to your camera to a desktop or where ever you save your photos to. A settings reboot may be needed to refresh your cameras software
Posted on Aug 06, 2012
1 Related Answer
Ty Price
  • 11967 Answers
SOURCE: When powered on the lens activates but doesn't
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 23, 2010
Eos 5D lcd screen stays black when power is turned on. It will show menu and review photos taken but otherwise remains black so it will not show what is in front of the lens.
Unfortunately the 5D (original) doesn't have live-view - which allows you to see the picture before you take it. It doesn't have video either but I guess you already knew that.
Mar 17, 2014 | Canon EOS-5D Digital Camera
The screen wont come up so i can see what im taking a picture of how can i fix this?
If you can see the menus and review pictures you've already taken then there's apparently nothing to fix. You have to use the viewfinder to compose your pictures, not the LCD on the back. The live view capability to use the LCD was introduced with later models.
Aug 03, 2012 | Canon Digital Rebel / EOS-300D Digital...
Sony cybershot t300 lcd screen remains dark when switched on
Your camera must be experiencing these symptoms due to a faulty CCD, and not due to other problems. If the problem is due to your dropping the camera, you might be out of luck.
If you have not dropped your camera and still facing this problem, then contact service people to replace the CCD imager in your camera .
Hope this helps .
Shane
Dec 21, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
I have a pentax ist DL digital SLR. The problem is that when you take a photo and try to review it the photo does not appear, it is just black. previously taken photos come up on the screen to review but...
Are you saying that on the same card, you are able to view other pictures you took but new pictures appear black? (or is this happening on different cards?)
Jun 07, 2011 | Pentax Cameras
Have a d8o take a picture does not show on back screen
If you wish to manually view all the photos you've taken, press the play button, it is located near the screen on the back with a triangle logo.
If you wish to automatically view photos after they've been taken, press the menu button, go to the sub menu with the pencil icon, and turn "Image review" to on.
If you wish to view the images on the back screen as you take them, this is not possible with the D80. You have to use the viewfinder.
Feb 12, 2011 | Nikon D80 Digital Camera with 18-135mm...
LCD montior not on to see picture before taking picture
On the EVOLT E-300 it is not a camera that has a live view LCD screen that will allow you to see the image before it is taken. You must take the image with viewfinder only and only use the LCD screen for review purposes. This is how the camera was designed.
Mar 15, 2009 | Olympus EVOLT E-300 (Double Lens Kit)...
No picture on lcd screen
I have the same problem but sadly no solution.
As my camera is still under warranty I took it back to Jessops.  The camera is now with Olympus for repair.  The technician in Jessops hazarded a guess that the problem is a broken processor sitting behind the lens and as such the problem is "really bad".
Here's hoping you are still under warranty.
Oct 22, 2007 | Olympus Stylus Verve / ?-mini Digital...
General Electric A1250 Digital Camera Logo
282 people viewed this question
Top General Electric Cameras Experts
Jeffrey Groves
Jeffrey Groves
Harrie
David Hoff
Are you a General Electric Camera Expert? Answer questions, earn points and help others
