Question about GE 29871GE3 Digital Answering Machine
Scratchy messages . ..how to repair????
Messages became scratchy, cannot be understood machine has no wear and tear....
Posted by Ingrid Blumenthal on
Slant-O-Matic 401. Bobbin tension to loose. Have tried turning screw, just won't fix this time.
It could be that the bobbin case is old and worn (normal with wear-n-tear). You should be able to find a replacement that will work. Check at the local sewing repair shop.
Sep 03, 2017 | Sewing Machines
How old is this model # AWS45NW ,Serial #040917265 Speed Queen Top Load Washing Machine . What type of wear and tear repairs can be expected down the road for normal use ?
That unit came out in 2006 it is still being sold. Motor and transmission are most common failures. The cost is 250 to 300 the most replaced item is the drive belt for 30 dollars
Jan 17, 2016 | Speed Queen AWS45NW Top Load Washer
My bobbin wonder is not engaging, how do I fix this?
In the meantime, you can pick up a standalone bobbin winder at the fabric store (or Amazon) for ~$25 US to wind your bobbins. Saves wear and tear on your machine and you also won't need to unthread your machine to wind a bobbin.
May 18, 2015 | Singer Merritt 8734
I rent and the landlord owns the washer. It is a Maytag front load stackable washer. Model # MHWZ400TQ01. I had used it once a week for about 6 months. I is over 5 years old. I noticed a tear in the...
issue him with a written notice of the tear ( also take a photo) so that he cannot blame you for the problem
It is not your fault but normal wear and tear for a machine that old
It sounds like he is trying it on so that you have to fix it
unfortunately it is his machine and repairs are his responsibility regardless of how rough or careful you are
if push comes to shove talk with a lawyer
Mar 29, 2017 | Maytag EPIC MFW9700S Front Load Washer
DRIVERS DOOR WILL NOT OPEN FROM THE INSIDE
you need to pull the door panel and see what became disconnected / wire rod linkages cause grief in the doors .and i've even seen some instances where the pieces lose plastic bushing parts and fall apart . as long as they make cars out of plastic / things will break in the cold and average wear and tear .
Dec 10, 2009 | 2002 Nissan Sentra
Water leaking in front of washer mainly from what seems to be the gasket around front of washer.
Either the rubber boot is damaged in some way, or the door is not locking tight enough. Thoroughly inspect the boot for tears or gouges in the rubber surface. Small imperfections can be repaired with silicon glue, but larger tears will require replacement of the boot--which can be done done through the door opening, but requires patience to do so. Inspect the door lock for damage or wear if the boot looks to be in good condition.
Oct 12, 2009 | LG WM2277H Front Load Washer
What causes the tears in the bellow seals on front loaded washers
It’s caused by gradual wear and tear through the vibration of the machine and rotation of the drum. If they are breaking down too often then it may be that your washing detergent mix or use of bleach or how you clean the bellows is weakening the rubber. Also excessive and heavy loads put more stress on the drum and can cause the drum to lurch dramatically from side to side which will end up in causing the bellows to wear / tear.
Oct 06, 2009 | Washing Machines
Titanium ventilate issues
Remove the milk frother,checked to see if it is blocked.
This can cause the machine not to ventilate correctly.
They tend to block with old hard milk.
Aug 26, 2008 | Gaggia Titanium Espresso Machine
Key pad
Thats a very very common problem with razrs. Seen it a million times. Its the "button flex" that became "bad" . Happens often on that model, its regular wear and tear. It should be covered under your service providors warranty. Just go to a local srvice center, the repair should take about 20 min. If you have any other questions, feel free to ask us
Jan 25, 2008 | Motorola Mobility RAZR V3
KLH Scratchy Channel
Return the unit to where you purchased it and get a new one.
Sep 19, 2006 | KLH R3100 Receiver
GE 29871GE3 Digital Answering Machine Logo
Top GE Lands Phones Experts
Bruce Robin
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
