Question about LG 42LG30 42 in. LCD HDTV
Problem with LG 42LK450 42 in. LCD TV Lost picture but sound can still be heard
TV only six months old suddenly no picture while sound and all other fuctions work. Checked cables and connections ran on HDM1 and AV with same result.
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
Anonymous
  • 3 Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: LG 42'' TV has no sound but great picture. How do I get the sound?
You shouldn't need anything plugged into the accessory jacks to get local sound from your set. Go through the main setup menu and check audio settings; they may be set to turn off the internal speakers to send the sound to a home theatre that you apparently don't have. Most sets have that as a selection and supply L-R audio for an external system and mute the internal speakers.
FYI: The three connectors you mention are coded as follows:
Red - right channel audio White - left channel audio Yellow - composite video (contains synchronization signals and video)
These may be input connectors (for external VCR/DVD decks) so check your owner's guide to verify.
Posted on Nov 23, 2008
Anonymous
SOURCE: LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Posted on Feb 21, 2009
Anonymous
  • 13 Answers
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Posted on Apr 28, 2009
Samsung LED UA40F6400 suddenly lost picture.
The tcon board or the LCD panel is faulty. You have to replace the TCON board to confim the fault.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 06, 2016 | Samsung 40 Inch UA40F6400 Full HD 3D Smart...
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
47LG70 - PICTURE WENT OUT. STILL HAVE SOUND. HEARD A POPPING NOISE WHEN PICTURE WENT. TV IS ONLY 1 1/2 YEARS OLD. ANY IDEAS WHAT MAY OF HAPPENED.
I have had the same problem off and on with my 47LG70 for months. When the "popping" noise happens, the blue light in the corner stays on, so I know the tv is still on (sometimes I still have sound, sometimes I don't). Sometimes the screen goes black, but other times it is blue. If I turn the tv off then on again, it might stay on for seconds, minutes or hours. It's been very frustrating.
This seemed to happen right after I got my new Comcast box, which came with an HDMI 1.3 cable. I read somewhere online that this tv might not be compatible with that cable, so I unplugged it and am using component cables again. I just did this today, so I don't know if it will work, but so far the tv has been on for 30 minutes with no problems.
I'm pretty ignorant about HDMI compared to component cables. I imagine I will not get as good a picture with the component cables, but I am willing to sacrifice quality if I can just get the darn thing to work. Mine is also only 18 months old.
Hope this helps. If it doesn't, maybe someone else out there can help us both.
Sep 21, 2010 | LG 47LG70 42 in. LCD TV
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
LG TV completely dead
I'll think your power supply is down.
Since your tv is 15 month old, you've still got waranty left.
Just contact you supplier or LG service.
Kind regards,
Gerard
Jan 25, 2009 | LG 42LG50 42 in. LCD HDTV
LG RZ32LZ55
There could be two possible failures:
1. The backlights are defective (not a common failure for a 14 months old LCD) or the backlights driver/inverter is defective.
2. Power supply failure(very common failure on LCDs) will cause the symptoms you described.
May 22, 2008 | LG RZ-20LA70 20 in. LCD Television
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG 42LG30 42 in. LCD HDTV Logo
132 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
