BMw 318i 95 model Dolphin shape
SOURCE: battery drains in my 1984 BMW 318i
I have the same car I had the same problem.If you have the correct battery for your car with the same problem you have a short or positive ground in your dash/electric fuel pump/fuse box also be carefull of how you take the key from the ignition and if they're old replace them.
SOURCE: 1994 BMW 318i Fuse Box layout
the fuses u are looking for are as follows:
From the top left first row its# 4
then the bottom row its # 19
I also wanted to point out. from 1989 to 1996 the brake switch was the common failure for bmw's
the series it included were 318i, 525-540i, and all 7 series. if the fuses dont fix it.. its the switch
located under a panel u need remove on the drivers side on the steering collum
SOURCE: BMW 5 series - 2005 model - resetting service & waring lights
this needs to be done with a european capable scan tool,check around to see if someone has this tool, no other way sorry
