Question about Marshall Amplification Marshall MG15FX Guitar Combo Amplifier - 8 Inch, 15 Watts
The amp does not work at all even though the lights on the amp come on but when i connect it to the guitar no sound whatsoevva i checked the sound nobs on the guitar and the amp n all r ok but no soun
No sound even when the amp n its settings are completly fine
Posted by relston on
Mark Yount
    Problem Solver:
  • 7 Answers
Have you checked a different cable?. Also, when you plug in the unit, there should be a "pop" if everything is turned on. If there isn't, the connection is bad someplace.
Posted on Aug 07, 2012
1 Related Answer
tommyshow
  • 99 Answers
SOURCE: My Marshall Guitar amplifier Makes Noise From
the "nobs" that have the noise is what we call a "dirty pot" Some can be cleaned others are to far gone to ever work well again. To clean a "dirty pot" you need to get into the internal area of the amplifier. Most amps have screws in the bottom that hold the unit into the wood frame. unplug everthing from the amp. turn the unit upside down and remove the retaining screws. that should allow the guts" of the unit to slide out. don't force anything. then you should be able to see the "pot" from the top. If you can you get electric contact cleaner (I use the NAPA brand) and the spray stick (red tube) that comes with the can of contact cleaner. In a safe area (no flame or heat) you spray the contact cleaner on the top and sides of the "pot" then work the knob back and forth all the w ay to each end of the allowable movement but never try to go beyond where the knob wants to stop. repeat this at least three times. take care not to let the contact cleaner drip onto anything as it could leave a stain. I usually try to use a lot of newspaper under the unit and be careful not to use any more spray than you need. You should feel the pot getting easy to move as it gets cleaner. Let everytthing dry off before you reinstall the amp into the outside frame. Move slowly and take your time. If it works it will save you a lot of repair cost as changing out the pots is not fun and could cost almost as much as the amp is worth
Posted on Apr 20, 2011
My 800 watt powered mixer was working fine until a keyboardist plugged in his keys and amp. The sound would fade out. When it was unplugged, it worked fine. Later that even, another DJ with an 800-watt...
All sound equipment has to operate without overloads in any given place. The power source should always be examined at commercial gigs and worked out with other performers along with management. The only fix is to do these checks up front and make safe arrangements.
Mar 18, 2013 | Music
Vox mini3 hiss or white noise when reverb or delay is selected.
The way I've found this amp works is it always needs a certain amount of "Gain" from the gain nob in order to produce any sound.Unfortunately the more gain the more hiss and crunch at least thats been my experience, it could also be you have one of the filters "guitar sounds" left on.The guitar sounds nob has to be left on clean to attain pure clean.There could also be a connection problem.I have this at the moment.I have to bend my wire in the right place to keep the thing going.Another issue I have with his amp is its been replaced my first one just conked out completely I couldn't get the cash back when I asked so I just got another one.This new ones been fine but not without hiss.I think its a hissy amp I hate to say it.Not the best amp by a long shot.
Oct 13, 2011 | VOX Amplification Vox MINI 3 Amp Combo
I have a Roland xp60 that produces no sound! Everything else seems to be fine - the display registers that I am hitting the keys & even the skip-back sampling feature produces a wav file I can see on...
Two things come to mind: 1. These synths have mute and output control settings. Verify they are correct as even a factory reset might not set them to default. 2. The next thing is that the volume control itself is damaged which requires internal investigation. Was this working and was there an accident with it... dropping manhandling, or accident with power or cables? There could be a cable that has fallen off between the main board and where the audio outs and jacks are. Be very careful if you open this of ribbon cables from the halves of the shell.
Sep 17, 2011 | Roland FANTOMG8
Just bought a ps-6 today, tried it through my overall set up the pitch shifter, detuner & super bend are fine, as soon as i use the harmony setting it takes a sweet medium gain lead sound and adds the...
By ading in the harmony signals you are combining 3 signals so gain is probably going to be high you will have to reduce it before it goes to the amp or turn down the input gain of the amp.
NEVER use a pedal in the external effects loop of an amp as the levels are wrong.
Jul 26, 2011 | Roland Boss PS-6 Harmonist Pedal
I have a Fender Cyber Twin that does not save my settings. I can set up my volume,gain, treble ect.. hit save button to store the setting and if I switch settings to a different sound and back to the...
From the manual... is THIS the proceedure you are using to save the settings?
 T o SAVE:
1) Press the SAVE key once and a prompt displays the PLAYER’S
LOUNGE preset about to be replaced, (example prompt shown).
2) Rotate the DATA WHEEL to select a PLAYER’S LOUNGE preset to
overwrite with the currently active amp design
(last chance to press EXIT, cancelling the save).
3) Press the SAVE key a second time to complete the save.
Jan 24, 2010 | Music
When I turn the volume past 12 o clock on my PX320 when playing hard the sound clips out. Drops out completely. Any solution to this?
The numerical settingor position of the volume has very little meaning.
If you are clipping, you are overdriving the unit and the unit protects itself.
OFTEN WITH guitars that have preamplifiers built in, one can overdrive the bass amp very easily, even at low settings of the volume control..
Do not continue to overdrive the unit as it is hard on the speakers... without the clipper, you would likely have blown the speaker(s).
IF YOU NEED it louder, then buy a larger amp and speaker setup.
Jan 07, 2010 | Casio Music
No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
Sep 27, 2009 | Peavey Music
After a few minutes of use, there is clipping and sound cutting out with the guitar through. Vocal and harmony are fine. I tried using different guitar cords, different guitars, different amps to no avail....
I know you hate this answer, but it needs to be repaired. It has a circuit board inside, and there's really not a work-around. But it is broken. I totally understand about not wanting to send your gear out, especially if it's a pedal board you have set just right, and are completely usweed to using. You'll be a lot happier with it if you get it fixed though. Or find another one on eBay. I sold all me Digitech pedals when I got my Pod - but that's just me, I use a lot of distortions and it fit the bill better for me. I used Digitech pedals for about 20 years and thought I would hate anything else.
Take care.
Mark
Jun 05, 2009 | Digi-Tech Digitech Vocalist Live 4...
Guitar amp no sound or lighting
Ah yes: complete catastrophe. Usually when everything is not working, it is a single reason and when that single reason is fixed, so is the amp.
Based on what you tell me, I am going to say you have a bad power tube. And I will even go as far to say that you buy a set of tubes and play on them as long as you can. If so, then you not only burned up the tube, but weakened the power section and may have a slooow tube frier. I always tell customers: modern tubes have an effective life of less that 1200 or so hours and that varies. Replace the tubes once per year if you gig with the amp: period. Otherwise, guys like me (doing repairs) stay busy and the tube companies get rich selling tubes to amps with weakened power sections.
It sounds like you burned a power tube and blew a fuse. First, you need a new set of power tubes and some extra fuses (go to Radio Shack and set the value you need in SLOW BLOW fuses).
Then, replace all the power tubes. Don't worry about biasing yet, we are just seeing if there is a problem. Next, replace the fuse.
Turn on the amp and play on it at various volumes and settings. If all is well, take the amp to a tech and get it rebiased. If you can afford it, pay to have the grid/plate and other resistors changed so the power section will be like new (clean slate with new tubes). Your amp will love you for it.
Almost all of the amps I have worked on for performance problems (cant keep tubes to stay alive for very long) are directly related to end user use. When you use a tube until it blows it ALWAYS TAKES SOMETHING WITH THE TUBE WHEN IT GOES (like the power section components). The compents will be weakened and the tubes will 'wear' at different rates that can even move them out of the 20% tolerence they must be within to sound good. 99% of the time a board repair with a retube after a catastrophe fixes the amp until the next time it is 'run into the ground'. Tube amps are NOT invinceble: they are weak compared to solid state and expensive to own. But we love tubes because they sound great. I have solid state to knock around on, when when it counts, I play only with tubes. I have spent hundreds on good tubes because you do get what you pay for.
Hope this helps!
-mike
Mar 14, 2009 | Music
Marshall Amplification Marshall MG15FX Guitar Combo Amplifier - 8 Inch, 15 Watts Logo
238 people viewed this question
Top Marshall Amplification Music Experts
matt martin
matt martin
rhodesworks
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
