Question about Kenwood KM200 Chef Food Processor
My kenwood chef km 200 is leaking oil. I know that the grease has to be replaced in the gearbox. hou do I get to the gearbox? How do I open the machine. I can see only 2 screws on the one side of
Oil is slowly leaking into my bowl. Apparently this is the grease that has melted over the years. We live in South Africa. I can't find any electrical appliance company willing to open the machine.
Posted by maggie on
3 Related Answers
valeantudor
Tudor Valean
  • 787 Answers
SOURCE: Ihave flooded the inside of my Kenwood Chef KM 264
Once the liquid reaches the inside of the device, it's pretty much unserviceable. The thing is that the soup, being liquid, contains a lot of water which corrodes the internal circuits. Also, it creates short circuits on the main board. Even if you do manage to change a few parts and make it work again, it is just a matter of time until something else fails. I recommend buying a new one.
Posted on Feb 16, 2011
graemevm
Graeme van Malsen
  • 519 Answers
SOURCE: i have an old model
As another South African citizen I can sympathize with you when it comes to finding service & after care support.
Kenwood S.A.'s website tells you to take it back to the store where you purchased it. Great help that is?
They do however give a JHB number where you can contact them:
011 474-0153
Let me know if you have no joy from this number.
Best wishes,
Graemevm
Posted on Mar 24, 2011
HansPP
Hans Pearson
  • 2510 Answers
SOURCE: We got a Kenwood Chef mod a901 as a gift but no
The parts that may require service after a very long tim would be the gear box which would require a clean out and refill with grease and the output shafts which can be wiped clean and given a touch if grease as well. The motor bearings could do with the same treatment and all this calls for a strip down of the mixer. However, if there is no perceptable play in the drives and no strange noises, the unit is possibly best left alone with just the minimum lubrication being applied as you intimate.
Posted on Jul 12, 2011
Need to remove external covers so i can replace a gearbox on kenwood chef km001 mixer! any ideas?
Dont know what the problem is, you didnt say.
Merely take the screws out. Usually on the bottom
of the unit. Heres your big hint, possibly. Some screws
are hidden under the rubber feet.
Jul 31, 2014 | Kenwood KM336 Chef Food Processor
How do you remove the top and motor from KM200
I have the same problem, removed screws but it won't pass over the front gearbox spigot.
May 24, 2014 | Kenwood KM200 Chef Food Processor
Kenwood KM336 no power to beater or slow speed outlet
Hi. You have a broken gear in the gearbox either the first motion gear is loose on its shaft or less likely the vertical big gear is loose on its shaft. independent spares for the gearbox are available or complete gearbox
Aug 02, 2012 | Kenwood KM336 Chef Food Processor
We got a Kenwood Chef mod a901 as a gift but no service manual. This mixer has seen a lot of usage during its lifetime and I don't know whether it has been serviced regularly. Does it need regular...
Jul 12, 2011 | Kenwood Food Processors
Where can I find a manual for the A701 food mixer
They do not have a manual for the Kenwood Chef A701. However, there is a manual for a Kenwood Chef A701 available for download see www.kenwoodservice.co.uk/instructions/UK/instructions-A701.pdf. There is also some discussion on Martin Lewis' Money Saving Expert Forum see forums.moneysavingexpert.com, about instructions for the Kenwood Chef. I hope this is of some help to you.
Thank You.
Mar 09, 2011 | Kenwood Food Processors
Why is smoke coming from Kenwood chef A901
sounds to me like you may have burnt up the motor probaby by mixing to heavy of a load or running it too long, or by just being older. I would replace it as fixing it would be costly
Jul 13, 2010 | Kenwood Food Processors
I have a kenwood chef mod 703c the motor spins and drives the belt ok butwhen i engage the power switch the mixerhead does nothing, does not turn
The problem is that the clutchdog, which is normally engaged by the peg on the liquidiser cover, is worn. Remove the top casing of the machine by removing the 3 screws and all of the outlet covers. Then unscrew the top of the gear box and prise open carefully with a screwdriver to expose the gears. The clutch dog can be unscrewed. Remove the spring that is on the outside of the gearbox and replace it on the inside of the gearbox so that it pulls the clutch dog down permanently. This then needs to be screwed back once the top of the gearbox has been screwed back together. Sounds complicated but it will be obvious when you try it. The machine will then turn the main attachment hub but will remain engaged as for later model machines. Hope this helps. John UK
Jun 16, 2010 | Kenwood Food Processors
Need a replacement bowl for my Kenwood Chef
I have an Excel that has the D shaped bowl but the base of it is round. Since the Excel does have a round base you can fit any existing bowl onto the Kenwood including their newer stainless steel bowl.
Mar 13, 2009 | Food Processors
Kenwood KM200 Chef Food Processor Logo
Top Kenwood Food Processors Experts
Ross Keen
ADMIN Canada
ADMIN Canada
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
