Tools & Hardware - Others Logo
Question about Bosch Tools & Hardware - Others
How to change a planing blade on bosch PHO 150
Bosch planing machine pho150 model
soni
Salam
Posted on Apr 07, 2014
1 Related Answer
Anonymous
  • 298 Answers
SOURCE: how to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Posted on Dec 21, 2010
I am trying to find a manual for my Bosch pho 200 planer. There are non available to download. Can you possibly assist me? JOHAN
https://manuals.plus/bosch/pho-20-82-corded-compact-planer-manual#axzz7YG6vK5wp http://www.free-instruction-manuals.com/pdf/p3427802.pdf
How to fit bosch PHO 15-82 planer base plate
my 15-82 has only one blade.There is a plate with three allen bolts to undo.Under that are two more allen key bolts to to undo.The blade moves although these two bolts are tight.The plane when looking at the drum has 6 inline holes.
3helpful
2answers
How do I change a blade with the Bosch 1587VS?
you need to lift up on the knob to loosen the spindle and remove/install the blade. To install the blade you might need to turn it some and push up and when it is straight then you need to turn the knob while holding up on it till it is snug and then push the knob down.
How do I change the blades on a Bosch PST 2000 jigsaw
I couldn't find that specific model number Bosch saw, but here is the link to get user manuals from Bosch in case you mistyped it. (It's a long link that wouldn't all fit here, so I had to put a carriage return in it)
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx
Or they may have a similar saw under a new model number. Here's the current model number of a very popular saw that has a less-than-obvious blade changing method 1587avsk
Mar 05, 2010 • Bosch Saws
10helpful
How to fit bosch PHO 15-82 planer blades
How I change the blades in the Rs 15 saw machine bosch
To lock a blade in just push the blade in until you hear it click. This is what engages the blade. To disengage just turn the blade clamp until the blade pops out. This will lock it open until you insert a new blade.
Sep 08, 2009 • Bosch Saws
1helpful
I have a bosch jigsaw I purchased at auction.I can't figure out how to change the blade
There are two types of "quick release" mechanisms on the new Bosch jigsaws, the twist-top handle found on 1587 models, and the lower-lever found on the 1590's.
The "twist-top" is the black cap on the 1587 at the front of the saw. You must first put the orbiting control ( on the side of the saw ) to position number III. This releases pressure on the blade. Then you lift the black cap, rotate three or more turns counter-clockwise ( as seen from the top ) to release the locking mechanism. If the saw blade is cool, you can carefully remove it with a single one-quarter turn using your fingers. If the blade is still hot from sawing, use a pair of pliers, but be gentle. Hot blades can bend easily and jam.
The 1590 models are quite a bit easier. You still want to put the orbit control to position III to release pressure. But the quick-release is a simple flick of the black switch on the front face of the saw.
I still have my 30 year old Bosch with the screw-in blade holder. It still works and the saw still runs smooth as a sewing machine. If you are doing a lot of production work where you need to change blades frequently, the Bosch 1590 is the clear choice for quality and value. In thirty years of using Bosch tools, I have only had to do normal maintenance and had only one minor failure, which was the blade changing mechanism on the 1587 model. I broke it by tightening too far. SO, if you have a 1587 model, DO NOT OVER TIGHTEN. As it is, this non-warrantee repair only cost $16 bucks and took two days.
It should go without saying, but just to be safe I'll say it anyway... OBVIOUSLY, you should UNPLUG the tool when you are changing blades. Good luck!
Top Bosch Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
