Question about Panasonic TH-42PX50U 42 in. Plasma HDTV
I have a Panasonic TH-42PX50u that suddenly is stuck on one channel and no volume control either. Same whether using remote or on TV. Only turns on and off no other control.
Suddenly I have no control of the TV, either from the TV or remote except on and off. Can't change channels, volume or anything else.
    Genius:
  • 1,182 Answers
Try changing the input device to something you are sure, works such as a DVD player. Look for any loose contacts in RC jacks/sockets/Cable. Look for jammed buttons on remote and/or on control panel. Try removing the batteries from remote and operating from the control panel of TV. If these are ok, Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Posted on Aug 06, 2012
  • Paul Gaetano Aug 06, 2012
    Hello Parasuraman S,
    Hello Parasuraman, I had tried all of your suggestions with the exception of unplugging the TV. I will try that tonight and see if I have any success. Thanks for the feedback.
    Top Expert:
  • Panasonic Master
  • 76,204 Answers
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Posted on Apr 23, 2015
6ya staff
SOURCE:
Anonymous
SOURCE: Have no volume on only one channel on Panasonic TH-42PX60U
Try the SAP - same thing happened to me and had to cycle through the audio tracks to get audio back on for that one channel. Good Luck!!!
Posted on Jun 16, 2009
Anonymous
SOURCE: won't respond to volume or channel changes red light blinks 20x's when turned off.
It's definitely a firmware problem. I called Panasonic and they were very polite about the entire situation and sent me a SD card with the firmware update. If you don't have time and you're tired of listening to tv at the same volume there is a way to do a hard reset.
I figured that unplugging the unit would do this, but there is one other step that you have to do to ensure that this works.
Generally the power button on the tv is always in the "on" position, this is what allows the remote to work. In order to do a hard reset the on/off button must be in the off position. Make sure that is off, then unplug the unit, let it sit there for a minute or two and plug it back in. If the tv comes back on as soon as you plug it back into the wall/powerstrip then the button was not in the off position.
This isn't the best fix, you'll still need to get the firmware update but it will at least give you the ability to use your tv normally....well until it decides to randomly lock up on you again and you have to do this all over.
Posted on Oct 02, 2008
Anonymous
SOURCE: trying to find comcast digital code to use their
10250
Anonymous
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
Anonymous
SOURCE: MY PANASONIC FLAT SCREEN VOLUME AND TV CONTROL DOES NOT WORK!!
Try unplug the power cord while the tv is still on. plug it back after 5 mins. it should work.
Posted on Sep 08, 2009
How do i program a device using this remote
From what I can tell the EUR7627Z60 was originally shipped with the following Panasonic products: TH-37PX50U, TH-37PX50U, TH-42PD50, TH-42PD50U, TH-42PX50, TH-42PX50U, TH-42PX50UA, TH50PX50, TH50PX50U, TH-42PD50, TH-42PD50U
Here is the manual for the Panasonic: TH-37PX50U/TH-42PX50U/TH-50PX50U:
Panasonic TH 37PX50U Operating Instructions Manual
Best of luck!
Feb 03, 2016 | Panasonic EUR7627Z60 Remote Control
Tip
How to connect laptop to TV Panasonic TH-42PX50U
Hi,<br />i have TV Panasonic TH-42PX50U, but i don`t know how to connect it with laptop...<br /><span><span>Can I</span> <span>do it</span><span>?<br />because i bought cable and it doesn't works, when i connect they then on laptop is signal, but nothing happens on TV and laptop more... </span></span><span><span>I</span> <span>open the</span> <span>laptop</span> <span>program</span> <span>but</span> <span>there's</span> <span>no evidence to show... <br /><br />i hope somebody can help me!<br /></span></span>
on Dec 18, 2010 | Panasonic TCL42D2 42 in HDTVReady LCD TV
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
Panasonic Viera TH-50PX60U Plasma is stuck on one channel. Only the power function works on the remote and only the On/Off function works on the TV. Any ideas??
Forced to factory default: press and hold [VOLUME ( - )] on the TV and press [MENU] on the remote 2 seconds. Exit: Unplug Power to reset.
If it does not help, the main board need to replace. For further questions, please add your comment.
May 20, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Jun 06, 2009 | Panasonic TH-42PX60U Television
Cannot control volume
Dear Mbruce 1,
With set on press and hold the "Power and Action Buttons" on set, for about five seconds, set will turn off and then back on.
Please let us know!
Toprol
Oct 15, 2007 | Panasonic TH-50PX75U Plasma HDTV
Panasonic TH-42PX50U 42 in. Plasma HDTV Logo
663 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
