After an abrupt power outage, The speakers bagan to oscillate with a background noise. Tried DVD input with same results. Hooked up stereo to the speakers out section and sound is fine there.
SOURCE: no sound coming through tv speakers
Hi.
Some Large flat panel tv sets have seperate speakers that clip on to the side of tv set if you got the manual with the tv does it say about seperate speakers.
Or if it does have speakers with the tv set check that the audio frequency is set to your countries transmission frequency.
Example UK is PAL (I) If your not in uk try and find out what yours is.
http://dysonmanuals.llc.nu/
Chris..
SOURCE: getting stereo speakers to work with flat panel tv
if you hook the low-level audio-out from the tv to an input to the stereo unit, whatever you play on tv will send audio to surround/stereo reciever unit. look on back of tv for red &white AUDIO OUTPUT terminals. plug red/white audio cables from tv to the back of your stereo & plug into audio input of an open source on stereo (tv/video,aux. in,etc.) good luck!
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Testimonial: "very fast, thanks for the help!"
SOURCE: Sanyo DP46849 composite video input malfunction
Sounds like a damaged port or related circuitry. You could take it to a repair shop if you really want to use that port, wouldn't cost too much
SOURCE: sony kdl-40s4100 no red standby light.When power
Does it make a click sound when powered on?
