Samsung SMH9151 Microwave Oven Logo
Anonymous Posted on Aug 06, 2012
Samsung smh9151 turntable and inside light quit working at same time. Light tested good and it still heats. What's wrong?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 06, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
275
Points
6
Time for a new one
  • Anonymous Aug 06, 2012
    It's just over a year old. Any thoughts on what would cause the turntable anr light to stop working at the same time
2answers
Without any known event, the microwave clocked no longer keeps time and the microwave does not heat up food. The timer works and the tray rotates, but no heating.
You have 2 systems inside your microwave, one is working, one is not.
The working one has the electric motor to drive the turntable and the timer.
The other system includes the "magnetron", which is the heavy unit that makes the microwaves to cook the food.
A repairman can check the magnetron to see if it has failed, and there are a few units that have a replaceable fuse that could be blown.
You will not want to try to fix it yourself, without a good knowledge of such things, as there is often a capacitor inside, which can shock you really bad if you touch it in error.
God bless your efforts.
Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
Samsung SMH9151 trips breaker when plugged in
You have a sort circuit inside, call a repairman or take to the repair shop
Not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'';
Not heating food
heatman101 ;;
7helpful
2answers
The microwave will not heat food. It will turn on the turntable will go around and the time will count down but the food is not heated when done. tried different heat setting with no results.
This seems to be a common problem, there are three parts that will cause this, the magnetron "heats food" a common failure, the high voltage diode and capacitor are the other two culprits. The cost to repair will approach the price of a new oven.
2answers
All the electronics go and the light turns off when you shut the door but the microwave never heats-up. Samsung SMH9151
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
