Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Cold inlet and hot outlet are marked on top of water heater.
Usually there is a letter or word embossed into the metal top.
If tank is connected, then turn on hot water tap for a few moment and feel which pipe is hot.
Cold water enters bottom of tank through dip tube located on cold side. If hot and cold are reversed, the water heater will not perform as expected.
http://waterheatertimer.org/Water-heater-dip-tube.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Aug 06, 2012
SOURCE: no hot water
Take these steps, ensure you are recieving correct voltage to the heater. If this has been confirmed, then using an ohmmeter, with the power turned off, check the resistance through you heaters. You should read a resistance through the heater(s). If you read OL, it means the heater is broken, and if you read 0 the heater is shorted. Hope this helps
Posted on Mar 29, 2010
I am afraid that you have burned the heating element out or an inline fuse is burned out
Posted on May 19, 2010
Mar 17, 2017 | Water Water Heaters
Jan 09, 2015 | Water Water Heaters
Jun 15, 2014 | Water Heaters
Jul 20, 2012 | Water Heaters
Oct 02, 2010 | Whirlpool Water Heaters
Jun 26, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
May 16, 2010 | Rheem Tankless Hot Water Heater...
May 15, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Aug 21, 2009 | Water Heaters
Jul 07, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Mar 05, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
215 people viewed this question
