SOURCE: remove panel
the freezer panel has 2 fan motors, one for the i/m area and the other for cooling. there is 1 screw in the center of the panel, remove it and then the panel will have to be wedged out. it may seem like it is tight but go ahead and pull on the panel and it will come out.
before you can do this, you will need to remove the drawer and rails so you can get into the panel easily.
p.s. you didnt say why you want to remove this panel???
by the way, these units have problems with the fan motors causing poor cooling in the refr section.
SOURCE: water leaking into refrigerator
yes you have to take off the ice maker then remove the scews, sometimes there is a air channel that has to be removed which are held in by plastic tabs
SOURCE: ice on back wall but not freezing food and rattle noise. Moved all food to other freezer
This is a fairly common problem with these types of refrigerators. The design is set to defrost every 12 hours and be down for 1 hour to allow ice to melt on coils. More often than not the ice never fully melts and creates a blockage in the coils and in turn slows air flow. You can remove the screws in the back wall of freezer unit and unsnap the ice maker plug to allow access to the coil. Gently tilt the back plate forward. You can then unplug the ref. and help it thaw with a blow drier. If you are not comfortable removing the back plate then you can just unplug the ref. and let it thaw on its own. this may take a while. try to remove as much ice as you can from the back of the freezer wall by hand and prop the door open for a couple of hours to ensure that all the ice melts. The rattling sound you are hearing is the fan blades hitting the ice that is built up around it. As a precaution I recommend that these type of refrigerators get manual defrost simply by unplugging about once a month for about two (2) hours. I hope that this will help you out with the melted ice cream. Good luck.
SOURCE: Kenmore Elite Coldspot side by side Model #
check the fan that transfers the cold air from the freezer to the fridge. thats where it comes from if you didn't know that. also check the the fan on the condenser at the bottom of the fridge. it should be blowing hot air off the condenser to facilitate the elimination of the heat from the condensing unit, just like your a/c does on the houe.
SOURCE: kenmore refrig runs continuously- freezer
You may have an interior fan problem on the fridge side where as the air cannot circulate.
