SOURCE: Replacing charcoal filter on ge jvm2070
Please be sure the oven is unplugged.
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they're removed the vent grille just snaps out.
In some cases, an installer may have installed the oven so that the screws are covered up by the bottom cabinet. I hope that's not the case here...
SOURCE: touch pad does not work, clocke does, nothing else works
Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
simply replacing the touch pad will fix this issue.
SOURCE: How do I open the front panel of GE Spacemaker 2.0 ? Fuse?
there are screws either on top of or in the grille that allow you to remove it. after screws are removed, open the door, pull lightly toward you starting at the control side if it does not pull, then it may have to be pushed toward the hinge side, then pulled out. behind the grille, is the screw attaching the control panel. lift the panel up before pulling out. Just to add a thought,if the display lights up it is probably not the fuse, although, in some models there is a high voltage fuse, it is pretty rare.
SOURCE: GE jvm2070 microwave touch panel does not work,
The only thing you can do is re set the main board, unplug the unit fot a minimum of 1 hour then try it again, if not you main board is out (this is caused by replacing the light bulbs with out unplugging the micro most of the time) If it is not in warranty I would advise to replace rether than repair, you get an average of 7 years out of them these days. Good luck
SOURCE: ge over the renge microwave runs but no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjdhjd
Matthew, can you send me your contact info. I have a GE JVM2070SK02 with the same problem of the control panel. The lights and fan work but the panel does nothing.
