Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
F10 code on a Kenmore self-clean range model #970-6061
Hi. Last night the power went off in our house and this morning my stove is flashing F10. It will not clear when pushing any buttons. Any idea?
    Scholar:
  • 64 Answers
Your Kenmore oven has a built-in fault detector. When the oven detects an issue, the display screen on the control panel will flash a fault code. The F10 fault code on your Kenmore oven indicates that the thermal protector on your oven's control unit, or microcontroller (MCU), has overheated. If the MCU overheats, the computer stops all motor functions. Several items on your oven could cause the thermal protector to overheat. Therefore, you must troubleshoot the F10 code to determine why it appeared on your display panel. Instructions 1 Inspect the area around and behind the oven to ensure you did not place the oven next to a source of heat, such as a register vent or other appliance that becomes very hot. If this is the case, you must remove the oven from the heat source to prevent the issue from occurring again. 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears. 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
Posted on Aug 05, 2012
6ya staff
SOURCE:
Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
GENE
Sep 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Classic Wall Oven Model # C97047191-2 Serial # NF91008197 nothing on it works (was fine last night) checked the 3 fuses under the stove and the breaker is good on the electrical panel. Is there...
I think that the ONLY problem is to set properly the TIMER; The TIMER is set OFF and the OVEN does not work; try to push and/or release the timer buttons and it will work. I have the same problem and it is very unfortunate that I have no manuals.....
Oct 05, 2010 | Ovens
F1 flashing on gas stove-manual says to push clear-where is clear button
HI. This actual code cannot be cleared by pushing the Clear/off button. This actual button will usually be located on the touch pad and is a basic cancel button. You can try to reset the entire control board by simply unplugging the unit for 5 minutes. This may correct the issue. If resetting dose not correct this fault, the necessary actions are to have the defective main PCB replaced, asap.
F1 - Defective control board(PCB)
May 23, 2010 | Frigidaire FGB24S5A Gas Single Oven
Reset clock and oven light came on flashing
THERE IS A PROBLE WITH THE ERC (CLOCK) NOT TO SURE IF I WOULD USE IT EITHER. THE PART IS EASY TO CHANGE JUST TURN POWER OFF AT THE BREAKER FIRST. YOU CAN FIND THIS PART HERE.
http://www.searspartsdirect.com/partsdirec
Apr 22, 2010 | GE Profile JTP18 Electric Single Oven
Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 17, 2010 | Ovens
I HAVE A MAYTAG BUILT IN OVEN THAT WAS WORKING FINE LAST NIGHT AND GET UP THIS MORNING TO BAKE AND I AM GETTING, ITS FLASHING A F2 AND F7 ERROR CODE AND THE ALARM OR BEEPING IS GOING OFF
Hi You have a bad touch pad , there maybe a be a button stuck in , try running your fingers over all the touch buttons but i think the touch pad will need to be replaced as always remove the power before taking it a part
Dec 21, 2009 | Maytag CWE4800A Electric Single Oven
My oven display is beeping and blinking 'PBR' on the display. What does that mean?
I had this same problem last night.. I have been having problems with the oven shutting off on preheat.. That sort of stopped. Last night lost power to the house. When it returned the oven was beeping and flashing PBR. I turned off the breaker for a few mins. last night and it returned. It was bugging me so much that turned it off the whole night. Woke up this morning turned the breaker back on and it stopped. I don't think this is the total solution. I am thinking that eventually I am going to have to replace power board in this oven. Hope it works!
Sep 23, 2009 | Jenn-Air Ovens
Stoves oven genus 900 error codes
Hi phill6x6...try turning on the oven by the main button, and press and hold button 7 until it beeps. Hope this helps you, and a few others!!
Nov 18, 2008 | Stoves 720EF Electric Double Oven
AEG Oven
try setting the clock, it may be automatic
Mar 22, 2008 | AEG B2100-4 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
606 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
