After i replaced the battery and cleared my computer starts slow runs slow and windows help & support stop working and saids under construction what did i do wrong
You cleared your cmos while windows was installed. NEVER reset, clear or load default w/o backing up your system before. You changed something in the bios that is no more according with the windows configuration. Good to find what. Try to reconfigure your bios maybe it will solve your problem. But if not you've to reinstall windows.
SOURCE: low system battery
Try to make first boot device as harddisk and in the main menu disable the primary or secondary IDE/SATA that are not used...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
