Power starts, can hear the fan, give 3 beeps, one long beep and two short - but no display
One Long and Two Short Beeps the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard
video display circuitry issue
Test all power and data leads that attach to your hard drive IDE,SATA
hope this helps
