Question about Kitchen Ranges
Frigidaire gas range model ES330 error code SAb
Error cose SAb
Electrolux
  • Official Brand Answer
  • 4,342 Answers
This is SB mode, show room mode. To deactivate showroom mode, remove power and reapply. Press Cancel to bypass programming clock. Within 60 seconds of reapplying power, press Oven Light key and top oven Timer key simultaneously.
Posted on Aug 07, 2012
5 Related Answers
D Clare
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
Anonymous
SOURCE: bybass auto shutoff (frigidaire gas range ES340)
Look on page 10 of the use and care manual under "To Set Control for Continuous Bake or 12 Hour Energy Saving" Page 10 in my manual.
Posted on Sep 09, 2008
Anonymous
  • 9 Answers
SOURCE: Frigidaire Gas Range Oven not getting hot - FGF376CEFP
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
Posted on Apr 11, 2009
Anonymous
  • 998 Answers
SOURCE: Frigidaire gas range broiler element does not light.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Posted on Aug 22, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: whirlpool gas range m#SF114pxsq1 diplays an F1 error code
HI. This is a basic Electronic Range Control Board failure code. I would advise to try a hard reset. This may correct the fault, if the damage is not severe. Simply unplug, or shutdown the appropriate circuit breaker for five minutes. After the five minutes have passed, kindly re-introduce power to the unit once more. Try to preform a baking cycle. if the code continues to illuminate during the attempt to operate the range, simply replace the main electronic control board(ERC or Clock).
Posted on Nov 16, 2009
We had some sort of electric power failure last night lasting only a few seconds, but now none of the control buttons on the gas range function. In the time window 5a6 shows. No way to use the oven.
You are in Jewish Sabbath Mode, it is 'Sab'
Search Results Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab". To disable the Sabbath mode push and hold the Clock pad for 3 seconds.Nov 10, 2007
Maytag Oven WEIRD Error Code 5ab - Appliance Repair Forum
forum.appliancepartspros.com/oven.../2348-maytag-oven-weird-error-code-5ab.html Feedback
About this result
Will you tell me what error code 5A6 means on Maytag MGR6875ADQ ...
https://www.shopyourway.com/questions/1098960 Nov 24, 2010 - As indicated in the previous response, the 5A6 indicates that the range is in the Sabbath mode (SAb). The image below shows the information on this mode for your range. Press the CLOCK button and hold it for 3 deliberate seconds to cancel this Sabbath mode. The control should then work normally. what does the f-2 error code on my maytag oven mean?
26 Jun 2010
What does the SAB error code mean on my Maytag ...
1 answer
1 Jan 2010
How do I cancel the Sabbath mode on my Maytag range?
30 Dec 2008
What does an SA6 (or 5A6) error code mean on my ...
1 answer
13 Nov 2008
More results from www.shopyourway.com
Maytag Oven SAb error code - YouTube
? 0:54
https://www.youtube.com/watch?v=XUP1BOzqPUo Jan 1, 2014 - Uploaded by Life With Christ
The SAb error code will freeze your oven functionality and you will not be able to cook or program the oven ... Oven Repair including Ranges and Cooktops
Mar 12, 2018 | Kitchen Ranges
Tip
My oven displays error code 5AB
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
on Mar 05, 2010 | Ovens
What dose SA6 or SAb stand for?
Jun 24, 2015 | Kitchen Ranges
Screen reads sab & none of the functions work
Hello & Welcome to FixYa
SAB is not a error code and is displayed when the unit is set up to Sabbath mode. To reset this error code you can press and hould the CLOCK pad which is located below the display for around 15 seconds. If the problem returns then it is recommended to leave the unit unplugged for 72 hrs so that the problem is solved. Please get back to me if you have any other questions.
Kevin
Mar 12, 2011 | Kenmore 47153 Stainless Steel Dual Fuel...
Mitsubishi Triton air bag light "ON" and the error cose B1401 F ABG(1) DR Squib open. May I know how to solve.
Dec 08, 2010 | Mitsubishi Eclipse Spyder Cars & Trucks
Cose is 74
Disassemble the console. Reflow the GPU and the (H)ANA chips. Redo the thermal paste on the GPU. Some E74 errors can be stubborn and require more than one reflow.
Dec 23, 2009 | Microsoft Xbox 360 Console
Readout is stuck on 5Ab. Can't do anything with it
Hi.
Regards.
Jul 09, 2009 | Maytag MEW6530D Electric Single Oven
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
Range does not work-message on stovetop reads 5Ab
same exact thing happened to me! Its not reading *5Ab* it's reading "Sab" as in Sab MODE...PRESS AND HOLD THE CLOCK BUTTON FOR A TOTAL OF 4 LONG SECONDS!! AND WAAAM!! Your stove is fixed and back to normal..with the Time! lol
Oct 10, 2007 | Maytag MGR5751AD Gas Kitchen Range
Kitchen Ranges Logo
466 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Andrew Taylor
Andrew Taylor
Are you a Kitchen Range Expert? Answer questions, earn points and help others
