Gateway Support > Gateway MCP61PM-AM motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rnv.shtml
Click on - Product Views
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front panel go to, is the Front panel header.
If you need the pinout for the Front Panel header, click on -
S- Front Panel Connector
Looking at the different colors on the Front Panel header, and matching pin numbering;
Pin 2 = Orange with Yellow + sign.
Pin 4 is solid Orange.
Pin 6 is Green.
Pin 8 is Green
There is NO Pin 10.
Pin 1 is Red with a Yellow + sign.
Pin 3 is solid Red
Pin 5 is Blue
Pin 7 is Blue
Pin 9 is solid Yellow.
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Reserved for +5 Volts, and factory use.
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is No Pin 10. Just a blank spot. (Yellow)
Click on B - Processor Core Power, for the 4-pin ATX +12 Volt power cable connector, location on the motherboard.
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
[ Processor to the Top, Ram Memory slots to the Right;
the square white 4-socket hole connector, is straight over to the left, from the bottom left corner of the Processor socket ]
On the U - Intrusion Switch Connector?
I believe the style of switch used, is if it is open, then the computer will not work.
Therefore connect a small wire to those two pins.
(Same thing as the switch is Closed)
Need Molex female metal terminals?
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US
Could I be wrong about how the switch works? Yes.
Could be the alternate style where the switch is open, and removing the computer case cover, closes it.
In this case do not connect a jumper wire.
All the other wiring connections are shown.
Have a specific question on the wiring? Post back in a Comment.
Regards,
joecoolvette
SOURCE: HP MCP61PM-HM motherboard diagram
Hi RobPu,
I have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
ECS known as EliteGroup. Still nothing. Forms for the most part do not help, only with drivers. Drivers for the board can be found on Compaq's web site.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&cc=us&dlc=en&product=3411762
But the manual will not download. That's what is needed to hook up the front panel pins to you're case. I even looked for other possible boards who's layout was close to the MCP61PM-HM.
Nothing! I did find other Compaq PC's that also had the same board in it but after looking through the manuals, not one actuallys shows where to plug the front panel LED's on to the board. Why? Because Compaq does not support a user changing out their case for another. There is no money in that.
For the most part RobPu, system boards share some things in common. I am posting a picture for you. This pic is upside down for you so try & work with me here. Hook up you're LED's as shown. This should work for you. Pin 1 is you're starting point.
This is standard for ECS boards even if it's being sold by Compaq. Like I mentioned, for you it is posted unside down.
Try it, I'm sure it will work for you.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
SOURCE: MCP61PM-HM spdif pin assignment? trying to
+5v Out Ground
The one all by its self is the 5 volt
the one in the middle is SPDIF Out
the one next to this is ground
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
