I am trying to remove the cranks, in which I understand how to do. But everything I see says remove the crank bolt first and I simply cannot see how that is able to come out. Both sides are threaded and there is no way to pull it.
SOURCE: how do you kill people in tony hawk pro skater 3
i dont think u can, u can knock em over. get on s8 board and ride on top of them
SOURCE: I can't calibrate Tony hawk
Try turning your WII so that the dongle that comes with the game faces the skateboard. I had that same problem and this solved it.
SOURCE: Cant calibrate tony hawk shred
At last! My Son's Tony Hawk Shred board was one more try from being thown down the garden, as i have been trying since Christmas day, & finally there it was a board i could use. I've followed all bits of advice in a number of differant ways --- here's what worked for me, Turn off at the wall Sky TV, Turn off all lights (only tv turned on), put my crutches in another room (because large metal objects interfere with soft ware), Remove dog from room, Put senser bar on floor, Turn Wii console side on so that Dongle faced away from tv (aiming into centre of room), Place Shred board on floor facing tv/senser at about three feet away. Start process of game set up untill you get to choose a profile, Select profile, press & hold for 5 secs start button on board untill the four blue lights start to flash at a rate of about one flash per sec, then hold on same button untill blue lights flash quickly, then press & hold Dongle button untill Dongle light stays on, with in 2 secs game calibartion instructions start, BEWARE Tony Hawks responce when process starts is as annoying as not being able to get board started. Good luck when up & running it is one Awesome game!
