Question about Birds
What's a playtop birdcage?
Posted by hasher on
kolop
    New Friend:
  • 28 Answers
The playtop bird cage provides a space for your bird to exercise and explore its freedom outside of the bird cage, and usually includes bird cage feeders as well. A solid top on the playtop bird cage is excellent for collecting food and other bird messes while the bird is on top of the bird cage.
Posted on Aug 05, 2012
How to replace blower motor on 2003 mazda protege?
the blower motor is located under the dashboard on the passenger side. you will need to remove the glove compartment to have easy access to it
Aug 25, 2014 | 2003 Mazda Protege
I'm thinking about ordering the A&E Cage Co. Small Split Level Play Top Bird Cage. Can the divider be removed?
The great thing about this birdcage is that the divider can easily be removed. You can use it as a spacious one room cage without the divider or you can house two or more birds seperately by inserting the divider.
Feb 16, 2014 | Birds
No heat or air blowing inside unit
Are you sure you dont have a clogged Dryer Vnet?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Feb 09, 2014 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
Need some kind of flameless candles for dark, antique birdcage with very small opening in the back.
You can purchase battery-powered LED candles that flicker realistically. They are approximately the size of a tea candle
Sep 13, 2013 | Candle Impressions 16" Birdcage with...
I'm looking to order bird cages online do you have any recommendation?
I suggest you to have a look at http://www.birdcages.com/helpfulinfo.cfm. I personally purchased a parrot perches from their site and I was very pleased with their customer service and their products. If you're looking for a bird cage you'll find it there.
Aug 05, 2012 | Birds
Remove heater blower birdcage
if your trying to change the squirrel cage of the blower motor,
in the center of the cage,where the motor shaft comes up thru it,there is a pinch clip that you need to squeeze together and pull off,then pull cage of shaft
Dec 10, 2009 | 1999 GMC Jimmy
Birds Logo
266 people viewed this question
Top Birds Experts
Kardoc
Tom Chichester
NOEL
NOEL
Are you a Bird Expert? Answer questions, earn points and help others
