Question about Birds
I'm looking to order bird cages online do you have any recommendation?
Posted by hasher on
kolop
    New Friend:
  • 28 Answers
I suggest you to have a look at http://www.birdcages.com/helpfulinfo.cfm. I personally purchased a parrot perches from their site and I was very pleased with their customer service and their products. If you're looking for a bird cage you'll find it there.
Posted on Aug 05, 2012
1 Related Answer
Bird Man
  • 17 Answers
SOURCE: What's your problem?Our bird cage finish is chipping. Can I paint it myself?
My recommendation is to call the manufacturer for paint recommendations and, believe it or not, some cage manufacturers will do that for you. In any event, you must make sure the paint is nontoxic since most birds do scratch it with their beak. After painting Make sure you let it dry completely: Permit the paint to dry for at least 48 hours before moving your bird into the cage, so be prepared to have a secondary cage on hand. Also you should know that although paint may be nontoxic when dry, there are paints may be harmful to your bird if inhaled, so paint it as far as you can from your birds, outdoor area preferred.
Posted on May 14, 2012
How many toys should be in my bird's cage at a time?
The amount of toys varies according to the size of the cage. You will need to ensure that there is enough room in the cage for your bird to extend its wings and move freely. I would recommend using between 3-4 toys at a time. Keep in mind that it is a good idea to have extra toys set aside and to rotate them to keep your bird from becoming bored.
Aug 30, 2012 | Aspen Birds
Where can I buy a cover for my dome top bird cage online?
There are plenty of options to choose from. I will attach a few links to get you started, but I recommend doing a little shopping around of your own.
http://cozzzybird.com/
http://www.bird-supplies.net/dometop-covers.htm
http://www.birdcagesgalore.com/bird_Cage_Covers/Dome%20Top%20Covers%20cozzy%20cover.html
Aug 30, 2012 | Absorption Corp Birds
Is it ok to use a color-coated bird cage?
Some manufacturers design cages with a colored finish; however I do not recommend them. Birds will eventually gnaw the finish off. If you are set on buying a powder coated bird cage then I recommend the following site - http://www.birdcagesgalore.com/bird_cages_017.htm
Aug 29, 2012 | Birds
What's a single bird cage?
The single bird cage comes in a variety of sizes and is suitable for only one bird. Check bar spacing and the width of your bird's wing span to determine the best bird cage fit. Elevate this bird cage to sit at a human's chest level.
Aug 05, 2012 | Birds
What's a travel bird cage?
The travel bird cage is usually a smaller version of a normal bird cage. The travel bird cage does not need to be large, nor does it need to be as durable as your bird cage. Be sure that your bird can comfortably fit in this cage for a short amount of time so that it will not become stressed.
What's a playtop birdcage?
The playtop bird cage provides a space for your bird to exercise and explore its freedom outside of the bird cage, and usually includes bird cage feeders as well. A solid top on the playtop bird cage is excellent for collecting food and other bird messes while the bird is on top of the bird cage.
May 14, 2012 | Birds
Birds Logo
247 people viewed this question
Top Birds Experts
Kardoc
Tom Chichester
NOEL
NOEL
Are you a Bird Expert? Answer questions, earn points and help others
