Question about Birds
Does the size of my cage matters for my birds?
Posted by hasher on
monica
    New Friend:
  • 32 Answers
In general, the larger and the more active the bird, the larger the cage one should use. The amount of time the bird will spend in the cage each day is also a factor. A bird that is caged most of the time requires far more space than a bird caged only at night.
Posted on Aug 05, 2012
1 Related Answer
Bird Man
  • 17 Answers
SOURCE: What's your problem?Our bird cage finish is chipping. Can I paint it myself?
My recommendation is to call the manufacturer for paint recommendations and, believe it or not, some cage manufacturers will do that for you. In any event, you must make sure the paint is nontoxic since most birds do scratch it with their beak. After painting Make sure you let it dry completely: Permit the paint to dry for at least 48 hours before moving your bird into the cage, so be prepared to have a secondary cage on hand. Also you should know that although paint may be nontoxic when dry, there are paints may be harmful to your bird if inhaled, so paint it as far as you can from your birds, outdoor area preferred.
Posted on May 14, 2012
How many toys should be in my bird's cage at a time?
The amount of toys varies according to the size of the cage. You will need to ensure that there is enough room in the cage for your bird to extend its wings and move freely. I would recommend using between 3-4 toys at a time. Keep in mind that it is a good idea to have extra toys set aside and to rotate them to keep your bird from becoming bored.
Aug 30, 2012 | Aspen Birds
How many perches should I put in my bird's cage?
You should have a minimum of 3 perches - one for sleeping, and two others made of different materials and of varying sizes. This will give your bird enough variety without overcrowding the cage.
Aug 30, 2012 | Allied Precision Birds
In regards to bird cages, why is bar spacing so important? As long as the bird cannot fly out, then why does it really matter?
Inappropriate bar spacing can ultimately lead to injuring your bird. A cage where the bar spacing is too large could be hazardous to your bird, while a small distance between spacing will limit your birds view and also your view of your bird.
Aug 29, 2012 | Birds
When it comes to bird cages, why is size so important?
Cage size is a very crucial element in regards to proper bird care. The tail of your bird should never touch the back or bottom of the cage when sitting on their perch. A very general rule to follow is that the width of the cage should be at least 1-1/2 times as wide as your bird's wingspan. Keep in mind that it is not just your bird(s) inhabiting the cage but you will need a perch and most likely some toys. My personal recommendation is to buy the largest cage you can afford.
What size cage should I buy for my budgies?
Even though budgies are quite small, they are very active and need space to fly around and exercise. Budgies need a minimum cage size of 18"x18"x24". Here is a sizing chart that should answer any questions regarding bird species and cage size, along with particular suggested brands of cages to buy.
http://www.bird-supplies.net/size-chart.htm
What's a single bird cage?
The single bird cage comes in a variety of sizes and is suitable for only one bird. Check bar spacing and the width of your bird's wing span to determine the best bird cage fit. Elevate this bird cage to sit at a human's chest level.
Aug 05, 2012 | Birds
Do I need a Parrot perches?
Parrot perches are usually made for large sized birds. If you own a couple of small birds you don't really need this cage bur if you own more than 3 parrot you should consider a parrot perches to provide your birds the space they need.
Does it matter which cage I'll buy, vertical or horizontal?
Like all things each type has its advantages and disadvantages. Horizontal bars are easier to climb and vertical cages provide better visibility. There are brand which combine the two of them together and you should check out if it's suitable for you.
I have 4 cockatiels, what cage size should I get?
These are beautiful birds! Cage should be 24"x 22" x 30" for one bird - 1/2" to 3/4" bar spacing
May 13, 2012 | Birds
Birds Logo
249 people viewed this question
Top Birds Experts
Kardoc
Tom Chichester
Franck
Franck
Are you a Bird Expert? Answer questions, earn points and help others
