Question about Birds
What's a bird cage commonly made of?
Posted by hasher on
keath
    New Friend:
  • 14 Answers
The quality bird cages are often made of iron and the top quality are made of stainless steel. You can find other bird cages lessen in quality with low quality powder-coat or a painted finish.
Posted on Aug 05, 2012
1 Related Answer
Bird Man
  • 17 Answers
SOURCE: What's your problem?Our bird cage finish is chipping. Can I paint it myself?
My recommendation is to call the manufacturer for paint recommendations and, believe it or not, some cage manufacturers will do that for you. In any event, you must make sure the paint is nontoxic since most birds do scratch it with their beak. After painting Make sure you let it dry completely: Permit the paint to dry for at least 48 hours before moving your bird into the cage, so be prepared to have a secondary cage on hand. Also you should know that although paint may be nontoxic when dry, there are paints may be harmful to your bird if inhaled, so paint it as far as you can from your birds, outdoor area preferred.
Posted on May 14, 2012
How many toys should be in my bird's cage at a time?
The amount of toys varies according to the size of the cage. You will need to ensure that there is enough room in the cage for your bird to extend its wings and move freely. I would recommend using between 3-4 toys at a time. Keep in mind that it is a good idea to have extra toys set aside and to rotate them to keep your bird from becoming bored.
Aug 30, 2012 | Aspen Birds
How many perches should I put in my bird's cage?
You should have a minimum of 3 perches - one for sleeping, and two others made of different materials and of varying sizes. This will give your bird enough variety without overcrowding the cage.
Aug 30, 2012 | Allied Precision Birds
Is it necessary to cover my bird's cage at night?
This depends on your birds. If noise/light does not interrupt your bird from sleep than you should be fine without; however if your bird is easily disturbed, you may want to try using a cover so that they remain undisturbed.
Aug 30, 2012 | Absorption Corp Birds
What's a single bird cage?
The single bird cage comes in a variety of sizes and is suitable for only one bird. Check bar spacing and the width of your bird's wing span to determine the best bird cage fit. Elevate this bird cage to sit at a human's chest level.
Aug 05, 2012 | Birds
What's a travel bird cage?
The travel bird cage is usually a smaller version of a normal bird cage. The travel bird cage does not need to be large, nor does it need to be as durable as your bird cage. Be sure that your bird can comfortably fit in this cage for a short amount of time so that it will not become stressed.
What's a playtop birdcage?
The playtop bird cage provides a space for your bird to exercise and explore its freedom outside of the bird cage, and usually includes bird cage feeders as well. A solid top on the playtop bird cage is excellent for collecting food and other bird messes while the bird is on top of the bird cage.
I'm looking to order bird cages online do you have any recommendation?
I suggest you to have a look at http://www.birdcages.com/helpfulinfo.cfm. I personally purchased a parrot perches from their site and I was very pleased with their customer service and their products. If you're looking for a bird cage you'll find it there.
Does the size of my cage matters for my birds?
In general, the larger and the more active the bird, the larger the cage one should use. The amount of time the bird will spend in the cage each day is also a factor. A bird that is caged most of the time requires far more space than a bird caged only at night.
May 14, 2012 | Birds
Birds Logo
194 people viewed this question
Top Birds Experts
Kardoc
Tom Chichester
NOEL
NOEL
Are you a Bird Expert? Answer questions, earn points and help others
