Question about Nostalgia Electrics KPM-508 Popcorn Maker
Will not heat up and pop - Nostalgia Electrics KPM-508 Popcorn Maker
Posted by Patricia Poole on
Dan Webster
  • 8,220 Answers
Your power cord I would follow into the machine and hunt for a broken wire or a blown fuse possibly. Most pop corn makers are just about like a coffee pot. They have a klixon to control the temp and a couple of bullet fuses in line to prevent over heating. All of which is loacted on the base of the kettle. I wish I could be there to help ya get that popcorn popper working. Feetball season is nearly upon us.
Contact the makers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 05, 2012
Popcorn doesn't pop to full size. The problem is, the popcorn pops however the sise of the opoed corn is only one quater the sise it should be.
Not enough heat in the kettle to do the job. The corn will dry out and pop poorly when there is not enough heat. Either a thermostat adjustment or replacement or a bad element.
Feb 01, 2014 | Cretors Kitchen Appliances - Others
We Have a GE Model JVM 3670BF001 Spacemaker that started making a buzzing noise periodically when turned on. After a few times of buzzing it quit heating.
You probably had a bad connection now with pop probably separated. You may also have a bad thermal over heat device. one brand is Thermodisk. But you need to know what you are doing. Might be time to replace.
Oct 18, 2012 | General Electric JVM3670BF GE Profile 36"...
Hayward MILIVOLT H300 BANGING AND POPPING. STILL HEATS BANGING AND POPPING QUITS WHEN HEATING STOPS.
There are two things that can cause this...
low water flow
mineral build up in heat exchanger
Check and verify water flow through the heater
if that is ok, then the heat exchanger needs to be cleaned
heatman101
Sep 25, 2011 | Hayward H-series Electronic Gas Pool...
GE spacesaver microwave JVM1631WB002- making popping noise
The material is popping as a result of being heated.
Jan 19, 2018 | GE Microwave Ovens
Ge spacemaker xl 1800 - no heat
HI, the loud popping noise was the Magnetron tube. this is the main heating device. the noise filter is also damaged and, should be replaced as well.
In conclusion, replacing the Magnetron tube and noise filter will fix this unit.
Jun 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave will not function properly.
The cavity thermal fuse may have failed. It is located on the top of the cavity.
Jun 13, 2008 | Microwave Ovens
Popping plate not heating up
Remember the strirring rod connects to the motor, but the heating element connects via the two prongs in the rear, so the motor can run without the heating element turned on (turn on the base without the plate on...the motor runs fine). Try reattaching the plate...it needs a good connection to the connectors in the back. It should heat up pretty quickly. Also, if you put the heating pad in the dishwasher, make sure it is dry and that the contacts aren't tarnished.
I'm certain over time the contacts will get loose and the popper will stop working, but our is going fine after a year.
Also, be careful not to drop the base...lots of cheap, hard plastic that will break and rattle around.
Mar 01, 2008 | Cuisinart CPM-800 Popcorn Maker
Oven shuts off
It possibly incompatible heating element installed on the oven that's why it pops up when you try to turn on and heat it..
Feb 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Nostalgia Electrics KPM-508 Popcorn Maker Logo
344 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Robert
Anthony Ward
Anthony Ward
Tom Chichester
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
