I can't find the turn singal relay, my haynes book shows for a 95 ford explorer that its under the dash to the right of the stearing column, I found a relay box there but it was a group of 7 relays not what they show in the book, the book shows two large relays, and the truck manual does not indacate these are turn singal relays. and the auto part stores do not sell a turn singal relay, just the lever on the column. my problem is no turn singals no emr flashers, but all light are working. no clicking when turn singals are applied. the book says its the relay. However I can't find it to fix it?
SOURCE: Turn Signal Flasher location in 93 Mustang GT
The flasher is a small round plastic cylinder (unless replaced with a metal one) behind the left edge of the glove box that will look similar to the one in the fuse panel. The first step is to squeeze gently both sides of the open glove box and let it swing downward. It will be snapped into a metal horizontal brace just to the left of the glovebox opening by a small tab and have two wires attached. The number more than likely will be a #552 although I have seen a factory one with a Warner #224
SOURCE: where is the door lock relay located on a 1999
SOURCE: when you turn the right turn singal on it will
check front and rear bulbs.will not flash on dash if one out.
problem solved.
