Cars & Trucks Logo
Anonymous Posted on Aug 05, 2012
1992 Dodge d350 gas
Got check engine light on, comes up as dtc 41 and dtc 33, what could be the problem?
Jeffery Lewis
Level 3:
  • Master 329 Answers
  • Posted on Aug 05, 2012
Jeffery Lewis
Master
Level 3:
Answers
329
Questions
Helped
188242
Points
1340
Code 41 is for the Alternator field curcuit and the 33 is for the A/C curcuit .. Ck your battery grounds and for corrosion at the alternator connections . Also ck the A/C compressor relay and the ignition power relay ( or replace them they are cheep) Both codes have to do with low votage
  • Anonymous Aug 23, 2012
    i dont have a/c in the truck, also the oil pressure gauge is flopping around, idk if theres an oil pressure sensor that could be causing that?
5 Related Answers
Anonymous
  • 1627 Answers
  • Posted on Oct 17, 2009
SOURCE: 1997 dodge dakota 3.9l,change plugs wires dis cap
MAKE SURE YOU HAVE THE WIRES ON THE RIGHT PLUGS.YOU MAY NEED TO GET THE CODES SCANNED TO NARROW DOWN YOUR PROBLEM BUT I THINK IT'S A FIREING ORDER PROBLEM.IF THIS IS NOT THE CASE THEN DO A COMPRESSION TEST ON THE MOTOR TO SEE IF YOU NEED TO GO DEAPER.
Anonymous
  • 1341 Answers
  • Posted on Dec 08, 2009
SOURCE: 2004 Dodge Ram Diesel. Check engine light comes
You will need to have a diagnostic test on this vehicle which will then provide you some error codes.Then once you get the error code you can start looking where the fault is.Hope this helps.
TimtheStick
TimtheStick
  • 83 Answers
  • Posted on Dec 10, 2009
SOURCE: my check engine light comes on when my gas tank
I would pull the code first before anything else. Without the actual DTC, anyone who dares answer is just guessing.
Anonymous
  • 52 Answers
  • Posted on Feb 19, 2010
SOURCE: 2002 Dodge Ram Gas Engine. Check Engine light
check your antifreez . that would make check engine light come on and no heat
duane_wong
Duane Wong
  • 6826 Answers
  • Posted on Jul 22, 2010
SOURCE: 01 dodge ram 3.9 moter check engine light
Did you clear the code after replacing the gas cap and cracked hose?
You can do this with an OBD-II scanner from Walmart which costs under $100, or have the auto parts store do it that you bought your parts from if they are willing.
2answers
What other vehicle is a 1998 Dodge Durango serpentine belt compatible with
Terrell, !998 Durango serpentine belt also fits,
D150 Pickup RWD BaseV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
2 vehicles
1992 - 1993
D150 Pickup RWD BaseV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
1 vehicles
1993
D150 Pickup RWD BaseV8 - 5.9L vin Z 360ci - MFI GAS OHV
2 vehicles
1992 - 1993
D250 Pickup RWD BaseV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
2 vehicles
1992 - 1993
D250 Pickup RWD BaseV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
1 vehicles
1993
D250 Pickup RWD BaseV8 - 5.9L vin 5 360ci - MFI GAS OHV
1 vehicles
1993
D250 Pickup RWD BaseV8 - 5.9L vin Z 360ci - MFI GAS OHV
1 vehicles
1993
D350 Pickup RWD BaseV8 - 5.9L vin 5 360ci - MFI GAS OHV
1 vehicles
1993
D350 Pickup RWD BaseV8 - 5.9L vin Z 360ci - MFI GAS OHV
9 vehicles
1992 - 2003*
Dakota BaseV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
5 vehicles
1992 - 1999*
Dakota BaseV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
2 vehicles
1992 - 1993
Dakota LEV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
2 vehicles
1992 - 1993
Dakota LEV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
6 vehicles
1998 - 2003
Dakota R/TV8 - 5.9L vin Z 360ci - MFI GAS OHV
2 vehicles
1992 - 1993
Dakota SV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
2 vehicles
1992 - 1993
Dakota SV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
7 vehicles
1997 - 2003
Dakota SLTV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
3 vehicles
1997 - 1999
Dakota SLTV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
4 vehicles
2000 - 2003
Dakota SLTV8 - 5.9L vin Z 360ci - MFI GAS OHV
1 vehicles
2002
Dakota SXTV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
1 vehicles
2002
Dakota SXTV8 - 5.9L vin Z 360ci - MFI GAS OHV
9 vehicles
1992 - 2003*
Dakota SportV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
5 vehicles
1992 - 1999*
Dakota SportV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
4 vehicles
2000 - 2003
Dakota SportV8 - 5.9L vin Z 360ci - MFI GAS OHV
2 vehicles
1998 - 1999
Durango BaseV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
3 vehicles
1998 - 2000
Durango BaseV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
4 vehicles
1998 - 2001
Durango BaseV8 - 5.9L vin Z 360ci - MFI GAS OHV
4 vehicles
2000 - 2003
Durango R/TV8 - 5.9L vin Z 360ci - MFI GAS OHV
2 vehicles
1998 - 1999
Durango SLTV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
3 vehicles
1998 - 2000
Durango SLTV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
6 vehicles
1998 - 2003
Durango SLTV8 - 5.9L vin Z 360ci - MFI GAS OHV
1 vehicles
1999
Durango SLT PlusV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
2 vehicles
1999 - 2000
Durango SLT PlusV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
4 vehicles
1999 - 2003*
Durango SLT PlusV8 - 5.9L vin Z 360ci - MFI GAS OHV
1 vehicles
2003
Durango SXTV8 - 5.9L vin Z 360ci - MFI GAS OHV
1 vehicles
2000
Durango SportV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
3 vehicles
2000 - 2003*
Durango SportV8 - 5.9L vin Z 360ci - MFI GAS OHV
5 vehicles
1997 - 2001
Ram 1500 LaramieV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
1 vehicles
1997
Ram 1500 LaramieV8 - 5.2L vin T 318ci 5211cc - MFI CNG OHV
5 vehicles
1997 - 2001
Ram 1500 LaramieV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
5 vehicles
1997 - 2001
Ram 1500 LaramieV8 - 5.9L vin Z 360ci - MFI GAS OHV
2 vehicles
1997 - 1998
Ram 1500 SS/T 5.9LV8 - 5.9L vin Z 360ci - MFI GAS OHV
5 vehicles
1997 - 2001
Ram 1500 STV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
1 vehicles
1997
Ram 1500 STV8 - 5.2L vin T 318ci 5211cc - MFI CNG OHV
5 vehicles
1997 - 2001
Ram 1500 STV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
5 vehicles
1997 - 2001
Ram 1500 STV8 - 5.9L vin Z 360ci - MFI GAS OHV
5 vehicles
1997 - 2001
Ram 1500 SportV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
1 vehicles
1997
Ram 1500 SportV8 - 5.2L vin T 318ci 5211cc - MFI CNG OHV
5 vehicles
1997 - 2001
Ram 1500 SportV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
5 vehicles
1997 - 2001
Ram 1500 SportV8 - 5.9L vin Z 360ci - MFI GAS OHV
5 vehicles
1997 - 2001
Ram 1500 WSV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
6 vehicles
1997 - 2002
Ram 2500 BaseV8 - 5.9L vin Z 360ci - MFI GAS OHV
1 vehicles
2002
Ram 3500 BaseV8 - 5.9L vin 5 360ci - MFI GAS OHV
6 vehicles
1997 - 2002
Ram 3500 BaseV8 - 5.9L vin Z 360ci - MFI GAS OHV
2 vehicles
1992 - 1993
Ramcharger BaseV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
1 vehicles
1993
Ramcharger BaseV8 - 5.9L vin Z 360ci - MFI GAS OHV
2 vehicles
1992 - 1993
Ramcharger Canyon SportV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
1 vehicles
1993
Ramcharger Canyon SportV8 - 5.9L vin Z 360ci - MFI GAS OHV
2 vehicles
1992 - 1993
Ramcharger Royal SEV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
1 vehicles
1993
Ramcharger Royal SEV8 - 5.9L vin Z 360ci - MFI GAS OHV
2 vehicles
1992 - 1993
W150 Pickup 4WD BaseV6 - 3.9L vin X 239ci 3906cc - MFI GAS OHV
2 vehicles
1992 - 1993
W150 Pickup 4WD BaseV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
1 vehicles
1993
W150 Pickup 4WD BaseV8 - 5.9L vin Z 360ci - MFI GAS OHV
2 vehicles
1992 - 1993
W250 Pickup 4WD BaseV8 - 5.2L vin Y 318ci 5211cc - MFI GAS OHV
1 vehicles
1993
W250 Pickup 4WD BaseV8 - 5.9L vin 5 360ci - MFI GAS OHV
1 vehicles
1993
W250 Pickup 4WD BaseV8 - 5.9L vin Z 360ci - MFI GAS OHV
1 vehicles
1993
W350 Pickup 4WD BaseV8 - 5.9L vin 5 360ci - MFI GAS OHV
and maybe a couple more others.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
List Belts 1998 Dodge Durango Reilly Auto Parts
Get the Best Priced Dodge Durango Belts
http://www.autozone.com/cooling-heating-and-climate-control/belt/duralast-serpentine-belt/165321_17278_23387_5281
I have a 1992 dodge d350 and all my light work exept the running lights
No the TPS has nothing to do with lights. You likely need a new headlight switch and headlight switch connector, they get burned from the amperage load over time. Remove the switch and inspect it fro signs of discoloration from heat damage.Always replace the switch and the connector as one repair.Solder new connector in and heat shrink the solder joints, never use crimp connectors..
No running lights 92 dodge d350
what do you mean by tps and wgere is it located on the truck
10helpful
Dtc p0405 & p0406 these codes came up when i checked my dtc and would like to know what the codes are and what is needed to correct the problem. any help would be appreciated. I changed the oil and the...
The DTC P0405 is for (Exhaust Gas Recirculation Sensor Circuit "A" Low)
DTC P0406 is for (Exhaust Gas Recirculation Sensor Circuit "A" High)
This would indicate a problem with the EGR valve sensor, or the EGR valve itself is malfunctioning.
My check engine light comes on when my gas tank gets below half a tank on my 2005 dodge neon
1helpful
I have a 92' dodge turbo diesel with an auto
Check your tps with a ohm meter and see if you are getting varable resistance if you do not repace it and it will shift.I hope this helps you?
1helpful
What does the check engine light mean?
Whenever the "Check Engine" light comes on, there is always a DTC (Diagnostic Trouble Code) stored in the ECM (Engine Control Module). You'll need an OBDII (On-Board-Diagnostics) scanner to retrieve any codes recorded/set in ECM. Once you do this and let us know what, if any codes are set, then we can go from there.
How do you read the DTC´s from my Isuzu Bighorn 1992
a bighorn??should have an OBDII connection interface,then with the right software its not a problem.But by the time you pay for all that its cheaper to take it to garage
My engine light comes on and my car will not stay cranked
you need to take it to your nearest auto zone and let them run a test on your engine light its free and they should be able to tell you what it is reading
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
