Tv is turning volume up and down....changing channels like it is possesed and also the remote works once in a while. Not sure what is going on. Tried unpugging but not sure what makes it work and then not work. My husband fell alseep and all of a sudden the volume went quickly up for no reason with him out of the room???
That could be one of two things first being the front keyboard and possibly a main board. However the keyboard is usually the cause of those two issues. You can get replacement boards with free tech support for diagnosis to determine which board you actually need at www.tvrepairworld.com just hit the contact us button and enter the model number and symptom
SOURCE: NEW EMERSON 20" LCD STERO TV/DVD- NOT WORKING
the flash was the fuse inside the set blowing it usually takes out one or two diodes in the power supply section but maybeyou got lucky and its only the fuse.
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
SOURCE: reset my dish network box and now my remote doesnt
Try doing a scan for the codes, Dnt put in numbers manually!
SOURCE: Direct TV remote does not control TV on/off or volume.
hi! i have here a couple of codes for your tv, just try them, 1468, 1004, 1011, 1013, 1025, 1028, 1031, 1033, 1036, 1044, 1045, 1080, 1097, 1101, 1102, 1107, 1382, 1383, 1483, 1484, 1512, hope this helps!!!! goodluck!!!!
SOURCE: I have a new Emerson LC320EMX 32
Similar to mine, only my tv you can change channels. We either need someones help or atleast a service manual (not user manual)
