Question about Brother HL3075CW - HL-3075CW Wireless Laser Printer
Colored stripe down the edge
Brand new laser printer prints a colored stripe down theedgeof the paper first it wasbluethen red?
Posted by cerickson198 on
Doug
    New Friend:
    Problem Solver:
  • 10 Answers
Sounds like the transfer belt could be bad, however if your lines are just 1 color than replace that color toner cartridge
Posted on Aug 23, 2012
1 Related Answer
Norman Worley
  • 1273 Answers
SOURCE: why do my colored cartridges run out when I never
Unless you specifically tell the machine to only use the black cartridge, then it will mix your colors to make black ink. If then your black cartridge runs out it will also mix your colors.
Posted on Apr 16, 2011
My printer is low on yellow and magenta and is printing a stripe of each color on the papers edge.
Hi.
On the drums for each colour there is a purple/blue/green slider for cleaning the corona wire. If there is a stripe of colour anywhere on the page going from top to bottom check these sliders. They need to be where the arrow on the slider meets the arrow on the drum casing.
As for low toner on the Yellow and Magent - Replace the cartridges.
Jul 17, 2014 | Brother MFC-9325CW Wireless All-in-One...
Stripe down the middle of printed page
replace the transfer belt? and or color image units
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 31, 2014 | Konica Minolta magicolor 4650DN Laser...
Color register out how to setup it?
Go to the printer's control panel, Print quality, Calibration, Calibrate now. Then print Configuration page from Reports menu. Look at the bottom colored stripes. If some of the colors is fading at the edges, your laser scanner usnit needs mirror cleaning. To get it out remove the back and side covers, then disconnect all wires to the electronics at the back. Remove the entire metal frame with the PC boards. There is the laser scanner unit - a black plastic box. Remove the screws and open it.
The dust on the mirrors comes from the main fan next to the LSU. Remove the gratings (do not install back) and seal all vents with adhesive tape. This will not harm the printer.
Aug 21, 2010 | HP Color LaserJet 2600n Printer
During printing the printer prints a colored band down the length of the paper, the band moves across the paper...each sheet the band is in a different location
I had a similar problem where it would print the a few color lines on the edge of the paper going the full length of the longest side. Turned out to be the transfer belt.
You can first try to uninstall your drivers and reinstalling them from the cd or download them from the samsung website.
Apr 30, 2010 | Samsung CLP-510 Laser Printer
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Samsung CLP-510 Print Quality problem
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
Dec 01, 2007 | Samsung CLP-510 Laser Printer
Pictures printing with stripes of color in some programs but not all programs.
Try new injet cartidges. If your printer has separate head and ink combo, replace the jets. The high quality mode operates the piezo jets at full power and lower setting can cause jets not to open as far. On some preinters, your particalar problem can be the result of too thin paper and the economy setting being used. Use 18lb or 20lb paper and see if it still does it on normal print mode.
Apr 27, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Brother HL3075CW - HL-3075CW Wireless Laser Printer Logo
406 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
